path: root/include/configs/mt8512.h
2020-08-08Convert CONFIG_SYS_MMC_ENV_DEV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MMC_ENV_DEV CONFIG_SYS_MMC_ENV_PART Note that with this conversion we now have consistent behavior with respect to ensuring that we have always selected the correct MMC device and hardware partition. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-16ARM: MediaTek: add basic support for MT8512 boardsmingming lee
This adds a general board file based on MT8512 SoCs from MediaTek. Apart from the generic parts (cpu) we add some low level init codes and initialize the early clocks. This commit is adding the basic boot support for the MT8512 eMMC board. Signed-off-by: mingming lee <mingming.lee@mediatek.com>
