path: root/include/configs/ms7750se.h
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-19CMD: Drop CONFIG_CMD_DFL, it's not usedMarek Vasut
$ git grep CMD_DFL board/atc/ti113x.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/atc/ti113x.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); board/cpc45/pd67290.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/cpc45/pd67290.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); drivers/pcmcia/i82365.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ drivers/pcmcia/i82365.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); include/configs/MBX.h:#define CONFIG_CMD_DFL include/configs/MigoR.h:#define CONFIG_CMD_DFL include/configs/digsy_mtc.h:#define CONFIG_CMD_DFL include/configs/ms7722se.h:#define CONFIG_CMD_DFL include/configs/ms7750se.h:#define CONFIG_CMD_DFL include/configs/r2dplus.h:#define CONFIG_CMD_DFL include/configs/sh7757lcr.h:#define CONFIG_CMD_DFL include/configs/sh7785lcr.h:#define CONFIG_CMD_DFL Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pfister_Werner@intercontrol.de Cc: iwamatsu@nigauri.org Cc: nobuhiro.iwamatsu.yj@renesas.com Cc: vapier@gentoo.org Cc: wd@denx.de Cc: yoshihiro.shimoda.uh@renesas.com Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-02-02sh: Remove config.mk for ms7750se boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: rename config option TMU_CLK_DIVIDER to CONFIG_SYS_TMU_CLK_DIVJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-08-13serial: move CFG_SCIF_CONSOLE to CONFIG_SCIF_CONSOLEJean-Christophe PLAGNIOL-VILLARD
move also conditional compilation to Makefile Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-09-23sh: Update MS7750SE01 platformNobuhiro Iwamatsu
2007-05-13sh: MS7750SE support.Nobuhiro Iwamatsu
This adds support for the Hitachi MS7750SE. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
