The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Signed-off-by: York Sun <yorksun@freescale.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW
macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS.
This is necessary for the assembly-language code that relocates CCSR, since
the assembler does not understand 64-bit constants.
CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the
CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it
should not be defined in a board header file. Similarly,
CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so
it should also not be defined in the board header file.
CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that
CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT,
and so CCSR will not be relocated.
Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot
builds (e.g. NAND) are required to relocate CCSR only during the last stage
(i.e. the "real" U-Boot). All other stages should define
CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated.
README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros.
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548
processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash
memory, real time clock and additional serial EEPROM on i2c bus (enabled).
USB controller is available, but not presently enabled.
Additional board information is available at:
http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.aspx
Environment is configured to precede the actual u-boot image so that it's
located at the beginning of flash erase block (made necessary by the recent
changes to the embedded environment handling). This is achieved by means of
custom ld script.
Signed-off-by: Alex Dubov <oakad@yahoo.com>
