path: root/include/configs/mpc8308_p1m.h
2011-11-03mpc83xx: Cleanup usage of LBC constantsJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-03mpc83xx: Cleanup usage of DDR constantsJoe Hershberger
2011-11-03mpc83xx: Cleanup usage of BAT constantsJoe Hershberger
2011-11-03mpc83xx: cosmetic: mpc8308_p1m.h checkpatch complianceJoe Hershberger
2010-09-23mpc83xx: extend CONFIG_SYS_BOOTMAPSZ increase to mpc8308_p1mKim Phillips
continuation of commit 39da1ba923d55f316f9f1bb3a960e4ed91dc17ac: "e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernels" Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23mpc8308_p1m: support for MPC8308 P1M boardIlya Yanok
This patch provides support for MPC8308 P1M board with the following set of features: Dual UART is supported NOR flash is supported Both TSEC Ethernet controllers are supported PCI Express initialization is supported Both I2C controllers are supported Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
