path: root/include/configs/mpc7448hpc2.h
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-10-27GCC4.6: Squash GTREADREG related errorsMarek Vasut
interrupts.c: In function 'interrupt_init_cpu': interrupts.c:37: warning: implicit declaration of function 'GTREGREAD' interrupts.c:37: error: 'LOW_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:37: error: (Each undeclared identifier is reported only once interrupts.c:37: error: for each function it appears in.) interrupts.c:37: error: 'HIGH_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: 'ETHERNET0_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: 'ETHERNET1_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:40: error: 'ETHERNET2_INTERRUPT_CAUSE_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET0_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET1_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) interrupts.c:44: error: 'ETHERNET2_INTERRUPT_MASK_REGISTER' undeclared (first use in this function) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2009-09-22FDT: remove obsolete OF_CPU and OF_SOC macros.Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12mpc7448hpc2: Add CONFIG_SYS_I2C_SPEED definePeter Tyser
Add standard CONFIG_SYS_I2C_SPEED define for the mpc7448hpc2 so that it can use the common 'i2c speed' command. Note that the I2C controller utilized by the mpc7448hpc2 has a fixed speed and cannot be changed dynamically. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-06-09Remove the deprecated CONFIG_OF_FLAT_TREEGerald Van Baren
Use CONFIG_OF_LIBFDT instead to support flattened device trees. It is cleaner, has better functionality, and is better supported. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-06-09Convert mpc7448hpc2 to CONFIG_OF_LIBFDTGerald Van Baren
This was configured to use the deprecated CONFIG_OF_FLAT_TREE, change to CONFIG_OF_LIBFDT. WARNING: This conversion is untested because I do not have a board to test it on. NOTE: The FDT blob (DTS) must have an /aliases/ethernet0 and (optionally) /aliases/ethernet1 property for the ethernet to work. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-02Fix build errors and warnings / code cleanup.Wolfgang Denk
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various m* named board config files.Jon Loeliger
2007-03-04Some code cleanup.Wolfgang Denk
2007-01-22use CFG_WRITE_SWAPPED_DATA define instead of define CFG_FLASH_CFI_SWAProy zang
The patch by Heiko Schocher <hs@pollux.denx.de> on Jan, 19, 2007 fixes cfi_driver bug for mpc7448hpc2 board. The default cfi_driver can support mpc7448hpc2 board.
2006-12-04Remove the static MAC address, ip address, server ip, netmask androy zang
gateway ip for network setting. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-12-04Remove the duplicate memory test code for mpc744ihpc2 board.roy zang
If a memory test is needed, please use the functions in post/memory.c or memtest command. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-12-01Fix the exception occuring in RAM table search issue.roy zang
The original search_one_table() function code can only processes the search for the exception occurring in FLASH/ROM, because the exception and fixup table usually locate in FLASH. If the exception address is also in FLASH, it will be OK. If the exception occurs in RAM, after the u-boot relocation, a relocation offset should be added. clean up the code in cpu/74xx_7xx/cpu.c Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-12-01Clean up the code according to codestyle:roy zang
(1) remove some C++ comments. (2) remove trailing white space. (3) remove trailing empty line. (4) Indentation by table. (5) remove {} in one line condition. (6) add space before '(' in function call. Remove some weird printf () output. Add necessary comments. Modified Makefile to support building in a separate directory.
2006-11-03Remove some unused CFG define.roy zang
undef CFG_DRAM_TEST
2006-11-02Add mpc7448hpc2 (mpc7448 + tsi108) board associated code support.roy zang
The mpc7448hpc2 board support header file. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
