CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
them from include/configs.
Also enable CONFIG_DISPLAY_BOARDINFO to get checkboard() called.
We do not have to define CONFIG_MPC512X in board config headers
because it is defined in arch/powerpc/cpu/mpc512x/config.mk.
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Make all mpc512x code point to the new common fsl_iim driver, and remove the
former mpc512x-specific iim driver.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Only define enabled clocks in the config file and enable
the clocks in common code.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Remove CSx configurations from board code and only define
required CSx macros in the board config file to configure
chip select windows and parameters.
Some of the boards using the mpc512x serial driver didn't properly
define which PSC console to use. This caused breakage when building
with CONFIG_SERIAL_MULTI enabled. Fix this by defining the default
PSC console.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
This change follows the change by Wolfgang Grandegger (commit 6c869637fef),
which allows to remove useless NAND_MAX_CHIPS definitions in board config
files.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Scott Wood <scottwood@freescale.com>
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Clean up the macro defintions used to enable DIU (video) support on the
MPC8610HPCD and the MPC5121ADS so that they look more like the P1022DS,
which is newer. Add software cursor support to all three boards.
Also document the CONFIG_FSL_DIU_FB in the README.
Acked-by: Anatolij Gustschin <agust@denx.de>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Signed-off-by: Francesco Rendine <francesco.rendine@valueteam.com>
Signed-off-by: Damien Dusha <d.dusha@gmail.com>
Coding style cleanup; slight file restructuring.
Acked-by: Remy Bohmer <linux@bohmer.net>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Newer Linux kernels can overrun the initial memory window used for
booting with their BSS area. When this happens, they overwrite the FDT
and silently fail to boot.
On e300 CPUs, the Linux kernel uses an initial BAT covering the first
256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase
the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value
allowed by Linux. This will allow very large kernels to boot.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
features
The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already
existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO).
So delete the 8610-specific code and use the built-in features instead.
Configure CONFIG_SYS_MAX_RAM_SIZE address range in
DDR Local Access Window and determine the RAM size.
Fix DDR LAW afterwards using detected RAM size.
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
Signed-off-by: Martha M Stan <mmarx@silicontkx.com>
Minor coding style cleanup.
Minor cleanup:
Re-ordered default_mddrc_config[] to have matching indices.
This allows to use the same index "N" for source and target fields;
before, we had code like this
out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]);
which always looked like a copy & paste error because 2 != 3.
Also, use NULL when meaning a null pointer.
When enabling NAND support for a board, one must also define
CONFIG_SYS_64BIT_VSPRINTF because this is needed in nand_util.c
for correct output.
This patch adds NAND support to the MPC5121ADS board. Please
note that the image size increased since NAND support didn't
fit in the current image size (256k).
