path: root/include/configs/mp2usb.h
2008-07-31Fix printf() format problems with configurable promptsWolfgang Denk
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not. To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-30use correct at91rm9200 register nameDavid Brownell
This fixes a naming bug for at91rm9200 lowlevel init code: NOR boot flash is on chipselect 0, not chipselect 2. This makes code use the register name from chip datasheets. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2008-02-04ARM: AT91RM9200 based boards config cleanupLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Remove nowhere used struct bd_info_ext, remove trailing whitespaces, fix indentation.
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various m* named board config files.Jon Loeliger
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-11-27Modified the mpc5xxx and the ppc4xx cpu to use the generic OHCI driverMarkus Klotzbuecher
and adapted board configs TQM5200 and yosemite accordingly. This commit also makes the maximum number of root hub ports configurable (CFG_USB_OHCI_MAX_ROOT_PORTS).
2006-05-23Changed the mp2usb (at91rm9200) board to use the generic OHCI driver. SomeMarkus Klotzbuecher
fixes to the latter.
2005-09-26Add support for AT91RM9200 OHCI Controller.Wolfgang Denk
Patch by Eric Benard, 07 Apr 2005
2005-09-26Add support for MP2USB board.Wolfgang Denk
