path: root/include/configs/motionpro.h
2010-10-20MPC52xx, motionpro: update default configurationWolfgang Denk
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-07-31Fix printf() format problems with configurable promptsWolfgang Denk
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not. To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2007-10-23Motion-PRO: Update configuration to accomodate next generation board.Bartlomiej Sieka
New board has faster oscillator and a different Flash chip. This affects: - CFG_MPC5XXX_CLKIN - SDRAM timings - Flash CS configuration (timings) - Flash sector size, and thus MTD partition layout - malloc() arena size (due to bigger Flash sectors) - smaller memory test range (due to bigger malloc() arena) This patch also enables more extensive memory testing via "mtest". Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various m* named board config files.Jon Loeliger
2007-05-27Motion-PRO: Code cleanup, fix of a typo in OF_STDOUT_PATH.Bartlomiej Sieka
2007-05-27Motion-PRO: Add support for redundant environment.Bartlomiej Sieka
Enable redundant environment, add a MTD partition for it; also add env. variable command for passing MTD partitions to the kernel command line. Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27Motion-PRO: Change maximum console buffer size from 256 to 1024 bytes.Bartlomiej Sieka
Allow passing longer command line to the kernel - useful especially for passing MTD partition layout. Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27Motion-PRO: Update EEPROM's page write bits and write delay.Bartlomiej Sieka
Change EEPROM configuration according to the datasheet: "The 24C01A and 24C02A have a page write capability of two bytes", and "This device offers fast (1ms) byte write". Add 3ms of extra delay. Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27MPC5XXX, Motion-PRO: Fix PHY initialization problem.Bartlomiej Sieka
After being reset in mpc5xxx_fec_init_phy(), PHY goes into FX mode, in which networking does not function. This commit switches PHY to TX mode by clearing the FX_SEL bit of Mode Control Register. It also reverses commit 008861a2f3ef2c062744d733787c7e530a1b8761, i.e., a temporary workaround. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27Motion-PRO: Add support for the temperature sensor.Bartlomiej Sieka
2007-05-27Motion-PRO: Add displaying of CPLD revision information during boot.Bartlomiej Sieka
Signed-off-by: Jan Wrobel <wrr@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-27Motion-PRO: Add LED support.Bartlomiej Sieka
Signed-off-by: Jan Wrobel <wrr@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-10[Motion-PRO] Add MTD and JFFS2 support, also add default partitionPiotr Kruszynski
definition.
2007-05-08[Motion-PRO] Add support for I2C, EEPROM and RTC.Piotr Kruszynski
2007-05-08[Motion-PRO] Add ATA support. Add CF-booting commands to the defaultBartlomiej Sieka
environment.
2007-05-08[Motion-PRO] Change IPB clock frequency from 50MHz to 100MHz. ThisBartlomiej Sieka
eliminates networking problems in Linux (timeouts).
2007-05-08[Motion-PRO] Enable Flat Device Tree support and modify default environmentBartlomiej Sieka
to allow booting of FDT-expecting kernels.
2007-02-09[Motion-PRO] Preliminary support for the Motion-PRO board.Bartlomiej Sieka
