path: root/include/configs/microblaze-generic.h
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SAVES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SAVES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_MMC_SPI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_MMC_SPI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-07configs: Replace deprecated Micrel defines with PHY_MICREL_KSZ90X1Alexandru Gagniuc
These boards will now use the ksz90x1 driver instead of the mess in ksz8xxx. This change is needed before the two drivers can be fully separated. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-14Convert CONFIG_SPL_RAM_DEVICE to defconfigStefan Agner
This converts the following to Kconfig: CONFIG_SPL_RAM_DEVICE Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10microblaze: Enable option to overwrite default variablesMichal Simek
Enable overwriting variables out of main config file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-10microblaze: Remove hardcoded IP address from configMichal Simek
IP addresses shouldn't be hardcoded in board config. This patch removes them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-10-15spl: move SYS_OS_BASE to KconfigHeiko Schocher
Move SYS_OS_BASE to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Also migrate a4m2k] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-08-08spl_nor.c: Support devicetree sizes different from 16kMike Looijmans
The devicetrees for various platforms already exceed 16k. Add a define CONFIG_SYS_FDT_SIZE to specify the FDT size, and set to 16k for the two boards that define this CONFIG_SYS_FDT_BASE parameter. This allows platforms with larger devicetree blobs to boot from NOR. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
2016-07-22microblaze: Remove empty ifdef around cachesMichal Simek
Code around was removed because of move to Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04microblaze: Remove !OF_CONTROL code for timer and interruptMichal Simek
OF_CONTROL is enabled by default that's why this is dead code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Fix board_init calling sequenceMichal Simek
board_init() is in final elf file but it is not called at all. Use board_init_late() instead and call gpio_init() from it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable HUSH via KconfigMichal Simek
Cleanup board file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Read information about RAM from DTMichal Simek
Do not setup ram start/size in board file. Read it from DT instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move CONFIG_NETCONSOLE to KconfigMichal Simek
2016-01-27microblaze: Remove CONFIG_FIT from board fileMichal Simek
And enable it via defconfig by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Remove systemace from board fileMichal Simek
Systemace is ancient IP which is not tested. Remove it from default configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move eth configuration to KconfigMichal Simek
Cleanup board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable axi emac via KconfigMichal Simek
Enable driver by default for all platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27microblaze: Enable MICREL_KSZ9021Michal Simek
To solve enabling ETH_DM where ksz90x1_reg_field is defined only when additional Micrel type is defined. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable PHYLIB via KconfigMichal Simek
Cleanup board configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable uart16550 DM by defaultMichal Simek
Microblaze is uses uartlite or uart16550 as console drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
