path: root/include/configs/mgcoge3ne.h
2011-05-10keymile boards: move keymile specific header in subdirValentin Longchamp
Collect all keymile specific common headers in include/configs/km. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com>
2011-05-10powerpc/km82xx: fix compile issue for mgcoge2neHolger Brunck
commit 91a3c14c (ppc, mgcoge: add DIP switch detection) introduces an compile error due to an missing define in the mgcoge2ne.h. DIP switch detection is valid for both boards. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Heiko Schocher <hs@denx.de>
2011-05-10poweprc/km82xx: add board specific environment variableHolger Brunck
On mgcoge3ne a new environment variable bobcatreset is used. So this patch adds a possibility to add board specific environment variables in general and this specific variable for mgcoge3ne. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
