path: root/include/configs/mgcoge.h
2011-05-10keymile boards: move keymile specific header in subdirValentin Longchamp
Collect all keymile specific common headers in include/configs/km. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com>
2011-05-10poweprc/km82xx: add board specific environment variableHolger Brunck
On mgcoge3ne a new environment variable bobcatreset is used. So this patch adds a possibility to add board specific environment variables in general and this specific variable for mgcoge3ne. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10powerpc/km82xx: rework DIP switch detectionHuber, Andreas
Introduce a struct for the BFTICU FPGA to increase the readability of the code. And the define CONFIG_SYS_BFTICU_BASE was removed because the CONFIG_SYS_FPGA_BASE is already the base value for BFTICU registers. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-04-30keymile, common: add setting of some environment variablesHeiko Schocher
This patch adds last_stage_init to all keymile boards. And in the last stage init some environment variables for u-boot were set. Currently these are pnvramaddr, pram and var address. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com>
2011-04-30ppc: add support for ppc based board mgcoge2neHeiko Schocher
The mgcoge2 board from keymile deploys two different processors. An ARM based Kirkwood for the "unit" part of the SW and a PPC for the "ne" part of the SW. Therefore in Linux and U-Boot the names for the board are mgcoge2un and mgcoge2ne. This patch adds the mgcoge2ne part of the board. The ppc part of mgboge2 is quite similar to mgcoge, therefore a generic header km82xx-common.h was introduced to collect all similiarities. Currently the only difference is that mgcoge2ne has a 64 MB numonyx NOR flash with a single die. The mgcoge has a dual die flash 2*32MB from spansion. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30arm, ppc: rework environment variables for keymile boardsHolger Brunck
This patch reworks all headerfiles for keymile boards. Furthermore the environment variables are refactored. Changes: - introduce km-powerpc.h file and extract ppc specific parts to it - move ARM specific options and vaiables to km_arm.h - sort the environment variables to logical groups - enhance the description of the environment variables - remove KM specific HW key and board id from kernel command line Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30ppc, arm: adapt keymile headerHolger Brunck
- adapt copyright string - change bootdelay to 2 seconds - set max number of command args to 32 - set I/O buffer size to 512 Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30keymile: Fix Coding style issues for keymile boards.Heiko Schocher
- use I/O accessors -> For accessing the FPGA therefore a struct km_bec_fpga is introduced. - no longer externs needed - to defines, that only select functions, don;t assign a numeric value - Codingstyle changes to prevent checkpatch errors/warnings Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-11ppc, mgcoge: add DIP switch detectionAndreas Huber
This reads the DIP switch on mgcoge. The DIP switch is connected to the BFTICU (0x40000089) FPGA. If the DIP switch is set the environment variable 'actual_bank' is set to 0 and starts the SW in bank0. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2009-09-22FDT: remove obsolete OF_CPU and OF_SOC macros.Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-09-15mpc8260: remove Ethernet node fixup to use generic FDT code.Marcel Ziswiler
Remove Ethernet node fixup from mgcoge and muas3001 boards and modify its configs for the common mpc8260 code to use generic Ethernet fixup. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Tested-by: Heiko Schocher <hs@denx.de>
2009-07-21powerpc: updates for the keymile boardsHeiko Schocher
- CONFIG_SYS_MAX_I2C_BUS changed to 1 We use only one I2C hardwarecontroller on this boards, so change the CONFIG_SYS_MAX_I2C_BUS to 1. - common: dont print errormsg if second IVM Block lacks. - 82xx, mgcoge: fix double mtdpart entry in environment - 82xx, mgcoge: activate on second Flash the second bank. - common: CONFIG_ENV_SIZE 0x4000 for all keymile boards - common: Change malloc size to 1MByte for all Keymile boards We need a bigger malloc area for the environment support (128k) on some Keymile boards (kmeter1) and the upcoming UBI support. Change it to 1MB for all Keymile boards to be on the save side. Also define CONFIG_SYS_64BIT_VSPRINTF which is needed for UBI/UBIFS support. - Add UBI support to all Keymile boards - change manner of writing "/localbus/ranges" node instead of writting the complete "/localbus/ranges" node before booting Linux, only update the ranges entries which gets dynamical detected (size of flashes). This is needed, because keymile adds in the DTS "/localbus/ranges" node entries, which u-boot must not overwrite/delete. - kmeter, mgcoge: define 2 seperate regions needed for the Intel P30 chips The Intel P30 chip has 2 non-identical chips on one die, so we need to define 2 seperate regions that are scanned by physmap_of independantly. - kmeter1: Add MTD concat support to Keymile boards - 82xx, mgcoge: add "unlock=yes" to default environment - added CONFIG_MTD_DEVICE to get in sync with mainline code Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-18powerpc: common updates for keymile boardsHeiko Schocher
- added to keymile-common.h: - bootcount support - COMMAND HISTORY - CONFIG_AUTO_COMPLETE - CONFIG_SYS_FLASH_PROTECTION - JFFS2 support - CONFIG_VERSION_VARIABLE - extracted common I2C settings for all boards - common default environment settings summarized Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-1882xx, mgcoge: fix environment sector sizeHeiko Schocher
Size of one environment sector is 0x20000. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-1982xx, mgcoge: updates for 2009.03Heiko Schocher
- activate CS4 for accessing the FPGA - activate Rx buf len > 1 on SMC - pram activated - MTDPARTS_DEFAULT defined - update the size of the flashes in the DTS before booting Linux - MONITOR_LEN updated to 384k - added CONFIG_HOSTNAME - added CONFIG_ENV_BUFFER_PRINT - Environment size reduced to 16k Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-1282xx, mgcoge: fix compile errorHeiko Schocher
With actual u-boot compiling the mgcoge port fails, because since commit ba705b5b1a97b47388ed48858bef6bf7b6bfcd56 it is necessary to define CONFIG_NET_MULTI. Seems to me the mgcoge port is the only actual existing 8260 port who uses CONFIG_ETHER_ON_SCC, so no other 8260 port needed to be fixed. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-01-24powerpc, keymile boards: extract identical config optionsHeiko Schocher
This patch extracts the identical config options for the keymile boards mgcoge, mgsuvd and kmeter1 in a new common config file keymile-common.h. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-01-24powerpc: keymile: Add a check for the PIGGY debug boardHeiko Schocher
Check the presence of the PIGGY on the keymile boards mgcoge, mgsuvd and kmeter1. If the PIGGY is not present, dont register this Ethernet device. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18mgcoge: add redundant environment sectorHeiko Schocher
2008-10-18mgcoge: added CONFIG_FIT to support the new u-boot image formatHeiko Schocher
2008-10-18mgsuvd, mgcoge: added BOOTCOUNT feature.Heiko Schocher
2008-10-18mgcoge, mgsuvd: added support for the IVM EEprom.Heiko Schocher
The EEprom contains some Manufacturerinformation, which are read from u-boot at boot time, and saved in same hush shell variables. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18I2C: adding new "i2c bus" Command to the I2C Subsystem.Heiko Schocher
With this Command it is possible to add new I2C Busses, which are behind 1 .. n I2C Muxes. Details see README. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18mgcoge, mgsuvd: add board specific I2C deblocking mechanism.Heiko Schocher
As documented in doc/I2C_Edge_Conditions, adding a board specific deblocking mechanism via CFG_I2C_INIT_BOARD for the mgcoge and mgsuvd board. This code was originally written by Keymile in association with Anatech and Atmel in 1998. The Code toggels the SCL until the SCA line goes to HIGH (max. 16 times). And after this, a start condition is sent. This is another approach to deblock the I2C Bus. The soft I2C driver actually sends 9 clocks with SDA High, and then a stop at the end, to deblock the I2C Bus. Maybe we should use the approach from Keymile as the new standard? Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18mgcoge, mgsuvd: add DTT (LM75) support.Heiko Schocher
2008-10-18mgcoge, mgsuvd: added EEprom support.Heiko Schocher
2008-10-18mgcoge, mgsuvd: add I2C support.Heiko Schocher
2008-04-17mgcoge, mgsuv: realign CONFIG_EXTRA_ENV_SETTINGDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-04-17mgcoge, mgsuv: rename 'addcon' to 'addcons'Detlev Zundel
The latter name with 13 users is already established, so we will use that. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-16mgcoge: update configurationHeiko Schocher
Fix configuration for mgcoge board Signed-off-by: Heiko Schocher <hs@denx.de>
2008-03-08mgcoge: update board configurationHeiko Schocher
add support for the config Flash. initialize the UPIOx controller. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2008-01-12Fix defaultconfig for the mgcoge board.Heiko Schocher
2008-01-12Added support for the mgcoge board from keymile.Heiko Schocher
