path: root/include/configs/mecp5123.h
2014-10-27powerpc: mecp5123: convert to generic boardAnatolij Gustschin
Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2014-01-24powerpc: mpc512x: remove redundant CONFIG_MPC512X definitionMasahiro Yamada
We do not have to define CONFIG_MPC512X in board config headers because it is defined in arch/powerpc/cpu/mpc512x/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-04-28mpc: iim: Switch to common fsl_iimBenoît Thébaudeau
Make all mpc512x code point to the new common fsl_iim driver, and remove the former mpc512x-specific iim driver. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-09mpc512x: use common code for clock setting for all mpc512x boardsAnatolij Gustschin
Only define enabled clocks in the config file and enable the clocks in common code. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Wolfgang Denk <wd@denx.de>
2013-03-09mpc512x: use common code for CSx configurationAnatolij Gustschin
Remove CSx configurations from board code and only define required CSx macros in the board config file to configure chip select windows and parameters. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Wolfgang Denk <wd@denx.de>
2012-10-15serial: mpc512x: Properly define CONFIG_SYS_PSC3 in config filesMarek Vasut
Some of the boards using the mpc512x serial driver didn't properly define which PSC console to use. This caused breakage when building with CONFIG_SERIAL_MULTI enabled. Fix this by defining the default PSC console. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernelsIra W. Snyder
Newer Linux kernels can overrun the initial memory window used for booting with their BSS area. When this happens, they overwrite the FDT and silently fail to boot. On e300 CPUs, the Linux kernel uses an initial BAT covering the first 256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value allowed by Linux. This will allow very large kernels to boot. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-04-24mpc5121: determine RAM size using get_ram_size()Anatolij Gustschin
Configure CONFIG_SYS_MAX_RAM_SIZE address range in DDR Local Access Window and determine the RAM size. Fix DDR LAW afterwards using detected RAM size. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-24mpc512x: make MEM IO Control configuration a board config optionAnatolij Gustschin
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-25mpc512x: Streamlined fixed_sdram() init sequence.Martha M Stan
Signed-off-by: Martha M Stan <mmarx@silicontkx.com> Minor cleanup: Re-ordered default_mddrc_config[] to have matching indices. This allows to use the same index "N" for source and target fields; before, we had code like this out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]); which always looked like a copy & paste error because 2 != 3. Also, use NULL when meaning a null pointer. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-20Remove last remanants of unused CONFIG_I2C_CMD_TREEPeter Tyser
2009-07-14MPC512x: fix typo in comment listing the NAND driver nameWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14mecp5123: cleanup - remove dead codeWolfgang Denk
Remove dead code that was obviously a left-over from copy & paste. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14MPC512x: enabling NAND support requires CONFIG_SYS_64BIT_VSPRINTFWolfgang Denk
When enabling NAND support for a board, one must also define CONFIG_SYS_64BIT_VSPRINTF because this is needed in nand_util.c for correct output. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-06-12mpc512x: Add esd gmbh mecp5123 board supportStefan Roese
MECP5123 is a MPC5121E based module by esd gmbh. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
