path: root/include/configs/mcx.h
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-01-08Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
This required manual merging drivers/mtd/nand/Makefile and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
2012-12-10OMAP3: Remove unused PHYS_SDRAM_1_SIZEThomas Weber
Remove the unused PHYS_SDRAM_1_SIZE from OMAP3 config files. Signed-off-by: Thomas Weber <thomas@tomweber.eu>
2012-11-26Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2012-11-26spl/nand: introduce CONFIG_SPL_NAND_DRIVERS, _BASE, and _ECC.Scott Wood
Some small SPLs do not use nand_base.c, and a subset of those also require a special driver. Some SPLs need software ECC but others can't fit it. All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these symbols added to preserve existing behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: use positive logic for including bits of NAND, rather than a MINIMAL symbol that excludes things.
2012-11-20boards: remove the no longer used CONFIG_EHCI_DCACHEJeroen Hofstee
CONFIG_EHCI_DCACHE was removed by commit b8adb12 "USB: Drop cache flush bloat in EHCI-HCD". Remove the defines from the boards configs as well. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> cc: Marek Vasut <marex@denx.de> cc: Stefan Roese <sr@denx.de> cc: Tom Rini <trini@ti.com> cc: Wolfgang Denk <wd@denx.de> cc: Thierry Reding <thierry.reding@avionic-design.de> cc: Tom Warren <twarren@nvidia.com> cc: Stephen Warren <swarren@nvidia.com> cc: Stefano Babic <sbabic@denx.de>
2012-10-25OMAP3: add video support to the mcx boardStefano Babic
Add video support to the board with the display focaltech etm070003dh6. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-25OMAP3: mcx: updated to new hardware revisionStefano Babic
Some GPIOs differ in the new revision board. Previous revision are considered obsolete and they will not anymore supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-25OMAP3: updated pinmux and environment for new revision of mcx boardStefano Babic
The mcx board was slightly modified and the pinmux must be updated. There is no need to support the old board, that becomes obsolete. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-09-27SPL: Move the omap SPL framework to common/splTom Rini
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL framework, enable on all of the previously using boards. We move the spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave the NAND one in-place as we plan to replace it later in this series. We use common/spl to avoid linker problems with respect to merging constant strings in objects. Otherwise all strings in common/ will be linked in and kept which grows SPL in size too much. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-27ARM: SPL: Move gpmc_init() to spl_board_init()Tom Rini
This is an OMAP/related-specific function, move calling it to spl_board_init() and turn on CONFIG_SPL_BOARD_INIT on the boards that enabled NAND and didn't enable this already. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01OMAP3: mcx: read hot-water-button after resetStefano Babic
Detect hot-water-button to start a differnt image. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@ti.com>
2012-09-01OMAP3: mcx: updated default environmentStefano Babic
Patch drops also not used CFI setup in the configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@ti.com>
2012-09-01mcx: increased buffer for command lineStefano Babic
2012-05-15ARM: omap3: Set SPL stack size to 8KB, image to 54KB.Tom Rini
With older toolchains it is possible to not fit entirely into the 45KB that we had assigned to SPL. Adjust to allow for 8KB of stack (which should be more than required) and 54KB of text/data. Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Thomas Weber <weber@corscience.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-27mcx: Enable command line editingDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Stefano Babic <sbabic@denx.de>
2012-02-27OMAP3: Remove unused CONFIG_SYS_NAND_ECCSTEPS/TOTALThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2012-02-12mcx: support for HTKW mcx boardIlya Yanok
This patch adds support for the HTKW mcx AM3517-based board. Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both NAND and MMC SPLs are supported. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
