path: root/include/configs/mccmon6.h
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-13spi: Migrate CONFIG_MXC_SPI to KconfigTuomas Tynkkynen
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-07configs: Replace deprecated Micrel defines with PHY_MICREL_KSZ90X1Alexandru Gagniuc
These boards will now use the ksz90x1 driver instead of the mess in ksz8xxx. This change is needed before the two drivers can be fully separated. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-12MCCMON6: defconfig: Add tftp_nor_dtb command for NOR DTB updateLukasz Majewski
Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-03-19MCCMON6: defconfig: Move 'quiet' console parameter to 'console' env variableLukasz Majewski
2017-01-30BOARD: MCCMON6: Provide support for iMX6q based mccmon6 boardLukasz Majewski
This patch provides u-boot support for Liebherr (LWN) mccmon6 board. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
