path: root/include/configs/malta.h
2016-05-31malta: Allow MIPS64 buildsPaul Burton
Both real Malta boards & emulators that mimic Malta (eg. QEMU) can support MIPS64 CPUs. Allow MIPS64 builds of U-Boot for such boards, which enables the user to make use of the whole 64 bit address space. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26malta: Use device model & tree for UARTPaul Burton
Make use of device model & device tree to probe the UART driver. This is the initial step in bringing Malta up to date with driver model, and allows for cleaner handling of the different I/O addresses for different system controllers by specifying the ISA bus address instead of a translated memory address. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-26malta: Tidy up UART address selectionPaul Burton
The address of the UART differs based upon the system controller because it's actually within the I/O port region, which is in a different location for each system controller. Rather than handling this as 2 UARTs with the correct one selected at runtime, use I/O port accessors for the UART such that access to it gets translated into the I/O port region automatically. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-01-16MIPS: malta: do not pull in target header files in config.hDaniel Schwierzeck
config.h is used in target and host code and therefore should not pull in target header files to avoid compile errors. This change is also required for the MIPS header file sync done in follow-up patches. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-01-29malta: enable ELF loadingPaul Burton
The ability to load ELF files is sometimes useful on Malta boards, particularly for use with small embedded applications. Enable the loadelf command in the malta config. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2015-01-29malta: enable HUSH parserPaul Burton
The malta board is used for development and thus the shell is interacted with often. Enable HUSH to make the experience a little more pleasant. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2015-01-29malta: IDE supportPaul Burton
This patch adds IDE support to the MIPS Malta board. The IDE controller is enabled after probing the PCI bus and otherwise just makes use of U-boot generic IDE support. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2015-01-21MIPS: add Kconfig option for CONFIG_SWAP_IO_SPACEDaniel Schwierzeck
2014-04-20MIPS: Malta: convert to generic boardPaul Burton
This patch converts the MIPS Malta development board to make use of the generic board code now that it is supported on MIPS. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-26malta: set CONFIG_SYS_BOOTM_LEN to 64MBPaul Burton
Allow a larger kernel binary to be decompressed - the default 8MB can become limiting on a Malta. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-26malta: correct UART baudratePaul Burton
CONFIG_SYS_NS16550_CLK specifies the rate of the clock 16x the baud rate. The SMSC FDC37M81x datasheet states that a divider of 1 results in a UART at 115200 baud, thus the x16 clock rate is 115200 * 16. Previously the divider was left at 0 which led to a rate of 38400 baud regardless of CONFIG_BAUDRATE or the baudrate environment variable. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-15malta: use unmapped flash base addressGabor Juhos
The physical base address of the NOR flash is 0x1e000000 on the Malta boards. The hardware also maps the first 4MiB of the flash into the 0x1fc00000-0x1fffffff range. Currently, U-Boot uses the mapped address to access the flash, which does not work in recent qemu versions. Since commit a427338b222b43197c2776cbc996936df0302f51 (mips_malta: correct reading MIPS revision at 0x1fc00010) writing to the mapped address space causes a CPU exception. Due to the exception, U-Boot hangs during boot when it tries to detect the CFI flash chip. Use the correct physical address for the MALTA_FLASH_BASE constant to fix the problem. In order to avoid relocation problems, also update the CONFIG_SYS_{TEXT,MONITOR}_BASE constants. The change makes it possible to start U-Boot on a Malta board emulated with Qemu 1.6.1 and 1.7.0-rc0. It also works on older versions (tested with 1.1.1, 1.2.2, 1.4.2, 1.5.3). Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: define CONFIG_MEMSIZE_IN_BYTESGabor Juhos
The memsize environment variable must contain the memory size in bytes on the Malta board. Otherwise Linux will use wrong memory size which causes a kernel panic. Define CONFIG_MEMSIZE_IN_BYTES in malta.h to avoid that. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: store environment in flashPaul Burton
Allow the environment to be stored in the monitor flash of a Malta board. The environment is stored in the final 128KB of the flash, which both leaves the majority of the flash available for U-boot code and also matches the location which YAMON uses. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: enable RTC supportPaul Burton
This is actually required in order for a Linux kernel to boot successfully on a physical Malta board. Without enabling the RTC, a Malta Linux kernel will get stuck in its estimate_frequencies function on boot. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: remove cache size definitionsPaul Burton
These will now be detected at runtime, allowing a single U-boot configuration to function correctly with different bitstreams. Without this you may need to re-configure, re-build and re-flash U-boot to your Malta if you flash a new bitstream with a different cache configuration to your old bitstream. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: enable CONFIG_PCNET_79C973, PCNET_HAS_PROM, CONFIG_CMD_DHCPPaul Burton
This model of the pcnet is used in current Malta boards, at least in the Malta-R rev 3. Enable support for it. The Malta also has the ethernet controller PROM containing its MAC address, so enable support for that in order to read that MAC address. DHCP is a very useful feature to have available for many networks, enable support for it also. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09malta: support for coreFPGA6 boardsPaul Burton
This patch adds support for running on Malta boards using coreFPGA6 core cards, including support for the msc01 system controller used with them. The system controller is detected at runtime allowing one U-boot binary to run on a Malta with either. Due to the PCI I/O base differing between Maltas using gt64120 & msc01 system controllers, the UART setup is modified slightly. A second UART is added so that there is one pointing at the correct address for each system controller. The Malta board then defines its own default_serial_console function to select the correct one at runtime. The incorrect UART will simply not function. Tested on: - A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both with and without an L2 cache. - QEMU. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09qemu-malta: rename to just "malta"Paul Burton
This is in preparation for adapting this board to function correctly on a physical MIPS Malta board. The board is moved into an "imgtec" vendor directory at the same time in order to ready us for any other boards supported by Imagination in the future. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
