path: root/include/configs/makalu.h
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-04-19CMD: Remove CMD_LOG, it's unusedMarek Vasut
$ git grep CMD_LOG include/configs/kilauea.h:#define CONFIG_CMD_LOG include/configs/lwmon5.h:#define CONFIG_CMD_LOG include/configs/makalu.h:#define CONFIG_CMD_LOG include/configs/quad100hd.h:#undef CONFIG_CMD_LOG include/configs/zeus.h:#define CONFIG_CMD_LOG Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2010-10-04ppc4xx: Use common ns16550 functions in 4xx UART POST driverStefan Roese
This patch changes the PPC4xx POST UART driver to use the common NS16550 functions for receiving and sending. Additionally the local function for SoC divisor setup are removed. Instead the functions from arch/powerpc/cpu/ppc4xx/4xx_uart.c are used. This removes code duplication. Also the common CONFIG_SYS_NS16550_COMx defines are now used to describe the POST UART's. And a compile breakage is fixed, introduced by a git merge of the ppc4xx/next branch into master. Now "ppc4xx.h" is moved to "asm/ppc4xx.h". Fixed as well with this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2008-08-13Merge branch 'Makefile' of git://git.denx.de/u-boot-armWolfgang Denk
2008-07-11ppc4xx: Add MII mode support to the EMAC RGMII BridgeGrant Erickson
This patch adds support for placing the RGMII bridge on the PPC405EX(r) into MII/GMII mode and allows a board-specific configuration to specify the bridge mode at compile-time. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-06ppc4xx: Unify AMCC's board config files (part 2/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Enable Primordial Stack for 40x and Unify ECC HandlingGrant Erickson
This patch (Part 2 of 2): * Rolls up a suite of changes to enable correct primordial stack and global data handling when the data cache is used for such a purpose for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS). * Related to the first, unifies DDR2 SDRAM and ECC initialization by eliminating redundant ECC initialization implementations and moving redundant SDRAM initialization out of board code into shared 4xx code. * Enables MCSR visibility on the 405EX(r). * Enables the use of the data cache for initial RAM on both AMCC's Kilauea and Makalu and removes a redundant CFG_POST_MEMORY flag from each board's CONFIG_POST value. - Removed, per Stefan Roese's request, defunct memory.c file for Makalu and rolled sdram_init from it into makalu.c. With respect to the 4xx DDR initialization and ECC unification, there is certainly more work that can and should be done (file renaming, etc.). However, that can be handled at a later date on a second or third pass. As it stands, this patch moves things forward in an incremental yet positive way for those platforms that utilize this code and the features associated with it. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-10ppc4xx: Update Makalu defconfig to use device-tree booting as defaultStefan Roese
This patch reworks the default environment on Makalu. Now "net_nfs" for example uses the device-tree style booting formerly know as "net_nfs_fdt". Also the addresses in RAM were changed because of the new image booting support, which check for image overwriting. So the addresses needed to get adjusted. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-01-17ppc4xx: Fix remaining CONFIG_COMMANDS in 4xx filesStefan Roese
2007-12-27ppc4xx: Update Makalu fdt supportStefan Roese
2007-12-08ppc4xx: 405EX: Correctly enable USB pinsStefan Roese
This patch selects the USB data pins in the 405EX GPIO and MFC (multi function control) registers. This is done for the AMCC Kilauea and Makalu eval boards. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-27ppc4xx: Kilauea & Makalu: Fix ext IRQ pin multiplexingStefan Roese
After an error in the AMCC 405EX users manual now correctly configure IRQ2 (Kilauea)/IRQ0 (Makalu) as alternate 2 signal for external IRQ usage. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-26ppc4xx: Makalu: Change EBC setup for CS0 to enable 400MHz usageStefan Roese
As suggested by Senao, use a different EBC_PB0AP setup for 400MHz operation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-16ppc4xx: Update AMCC Makalu for board rev 1.1Stefan Roese
This patch adds changes needed for Makalu rev 1.1: - Enable 2nd DDR2 bank resulting in 256MByte of SDRAM - Enable 2nd ethernet port EMAC1 - Use generic GPIO configuration framework (CFG_4xx_GPIO_TABLE) - Reset PCIe ports via GPIO upon bootup Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add SNTP support to AMCC Katmai, Kilauea & Makalu boardsStefan Roese
2007-10-31ppc4xx: Add initial AMCC Makalu 405EX supportStefan Roese
