path: root/include/configs/ma5d4evk.h
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-07configs: Finish migration of CONFIG_ATMEL_SPITom Rini
With the previous temporary reverts, we need to re-complete the migration of CONFIG_ATMEL_SPI here now. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-07Revert "spi: atmel: Drop non-dm code"Tom Rini
As we aren't quite able to convert some platforms with a very small size limit in SPL yet, we need to revert this for now. This reverts commit 7b0947787358c6b277431d6b76ce043d8bec641d. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2018-04-06spi: atmel: Drop non-dm codeJagan Teki
All board configs are now enabled DM_SPI for SPL and U-Boot proper, so now its time to drop non-dm code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_MASS_STORAGE to KconfigLukasz Majewski
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-10-03usb: gadget: usb_ether: Move settings to commonMaxime Ripard
The usb_ether gadget duplicates the USB settings for the manufacturer, product ID and vendor ID. Make sure we use the common option so that we can expect a single VID/PID couple for a single device. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: usb_ether: Move the interfaces to KconfigMaxime Ripard
We need to select an interface for the usb_ether gadget, and they haven't been converted to Kconfig yet. Add a choice to make sure we have an option selected, and convert all the users. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-14ARM: at91: Remove hardware.h included in configsWenyou Yang
As said in READRE.kconfig, include/configs/*.h will be removed after all options are switched to Kconfig. As the first step, remove the follow line from include/configs/*.h. #include <asm/hardware.h> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-06-29ARM: at91: ma5d4: Support both SF and eMMC SoMsMarek Vasut
Discern the SoMs based on the presence of SPI flash to support both variants of the SoM, one booting from SPI NOR and one booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Switch environment start to eMMCMarek Vasut
The redesigned version of the SoM which was released onto the market does no longer contain SPI flash, but boots from the eMMC. Move the environment storage to the eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Enable support for booting from eMMCMarek Vasut
The SoM has been redesigned to work around bug in the SoC and is now capable of booting from the eMMC. Add support for booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Swap SD/MMC controller orderMarek Vasut
The SDHCI1 is the primary boot controller on rev. 2.1 SoM, which is the version available on the market. Swap the controller order to match this and future versions of the SoM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Enable DFU and UMSMarek Vasut
Enable DFU and USB mass storage support for the DENX MA5D4 SoM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: atmel: Rename MA5D4EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-20Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: configs/bcm28155_ap_defconfig configs/dra72_evm_defconfig configs/dra74_evm_defconfig configs/ma5d4evk_defconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
