The various Aries Embedded boards have been orphaned for a year and no
one has come forward to take care of them. Remove.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every
use is couched by __stringify(...).
Hence, convert it to a proper string option.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
This macro is defined, but not referenced by anyone.
I did not touch config_whitelist.txt - the CONFIG will be dropped
by the next re-sync.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
Now that these symbols are in Kconfig, migrate all users. Use imply on
a number of platforms that default to having this enabled. As part of
this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
This option is pretty old. It predates CONFIG_SYS_I2C which is itself
deprecated in favour of driver model. Disable it for all boards.
Also drop I2C options which depend on this.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
[trini: default y if DM_RTC, re-sync]
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
With the latest mach-types values we have many instances where we no
longer need to define a value and a few cases where the name (but not
value) have changed slightly.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
This option only complicates the code unnecessarily, just use
CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are
only five arguments to eeprom {read/write} if this is defined.
If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all
six arguments.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Having this as a Kconfig allows it to be a dependent feature.
The patch below failed to define the variable, so define it
to make it consistent with M53EVK.
commit a428ac914b2b6db851c1feac98622f2d9844db45
Author: Lothar Rubusch <lothar@denx.de>
Date: Thu Jun 26 11:01:29 2014 +0200
ARM: m28evk: Update default environment
Cc: Tom Rini <trini@ti.com>
Remove this tab from env, since it's useless, just use spaces.
Enable the CONFIG_CMD_FS_GENERIC on m28evk to avoid per-fs specific commands
and tweak the environment to cater for this new option.
Make sure the boot.scr exists on the card before loading it
from the card to avoid annoying message on the console.
Signed-off-by: Lothar Rubusch <lothar@denx.de>
Adjust the mtdparts to also consider factory-programmed config block.
- "env ask", "env grep" and "setexpr" are needed for commissioning
- add support for ext4 file systems
- adjust default environment to use ext4 commands
- add write support for (V)FAT and EXT4
- add bitmap and splashscreen support
- print timestamp information for images
board/freescale/mx6qsabrelite/Makefile
board/freescale/mx6qsabrelite/mx6qsabrelite.c
include/configs/mx6qsabrelite.h
[trini: Fixup common/cmd_io.c]
Pull all the duplicate configuration options into configs/mxs.h
from the board configuration files. This reduces the files greatly
and makes them somewhat more readable. Besides, we do no longer
have such a horrible duplication of code.
Note that the mx23evk grew in size slightly. This is due to the
CONFIG_SYS_CBSIZE now being set to 1024 as it is on the rest of
MXS systems.
This patch also fixes the OCRAM size for i.MX23. The i.MX23 has
only 32kB of OCRAM, while i.MX28 has 128kB of OCRAM.
I verified the configuration didn't change for each of the boards,
but I didn't boot-test it on the boards I do not have. I configured
U-Boot for each board using the "make ... <board>_config" command
and then ran "cpp -I include -dM include/config.h" , which dumped
all the configuration options. I did this both before and after this
patch and finally compared the results for each MXS board. Actually,
the results do differ slightly, since the configs/mxs.h file now
properly includes the correct iomux-mx23.h or iomux-mx28.h , so
while comparing, I had to ignore these new defines. These have no
impact on U-Boot configuration though.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Lauri Hintsala <lauri.hintsala@bluegiga.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
this is usefull when writing an UBI image which contains
and UBIFS volume (check README.nand and UBI FAQ for more
details)
drivers/mtd/nand/mxc_nand_spl.c
include/configs/m28evk.h
Enable LCD output support on M28EVK.
Acked-by: Anatolij Gustschin <agust@denx.de>
