path: root/include/configs/m28evk.h
2012-08-09configs: Remove unused symbol CONFIG_DISCOVER_PHYFabio Estevam
CONFIG_DISCOVER_PHY is not used anywhere, so remove it from config files. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-07ARM: mx28: Remove CONFIG_ARCH_CPU_INITFabio Estevam
No need to define CONFIG_ARCH_CPU_INIT. All mx28 based boards should use arch_cpu_init(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-07-07m28evk: use same notation to alloc the 128kB stackOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Wolfgang Denk <wd@denx.de>
2012-07-07m28evk: drop duplicated definition of CONFIG_OF_LIBFDTOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-07-07m28evk: fix board config include guardian macro nameOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Marek Vasut <marex@denx.de>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15i.MX28: Implement boot pads sampling and reportingMarek Vasut
This patch implements code that samples i.MX28 boot pads and reports boot mode accordingly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-05-15M28EVK: Add SD update commandMarek Vasut
Add "update_sd_firmware" command to easily reload the SD card of m28evk kit. This comes handy when the board boots from SD card. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-05-15M28: Scan only first 512 MB of DRAM to avoid memory wraparoundMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com>
2012-05-15M28: Enable FDT supportMarek Vasut
This will eventually be needed with Linux 3.5, which will be the point when MXS will be switched to FDT. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com>
2012-05-15m28evk: Allow to booting a dt kernelFabio Estevam
Allow to booting a dt kernel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16M28: Pull out CONFIG_APBH_DMA so it's always enabledMarek Vasut
The ABPH DMA is now used also by the SD card. Therefore it has to be enabled even if NAND is disabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16i.MX28: Fix initial stack pointer positionMarek Vasut
The patch: m28evk: Use GENERATED_GBL_DATA_SIZE commit 1084606c972ea5f1d89f69bdbd978b867d0ee521 introduced usage of GENERATED_GBL_DATA_SIZE and calculation of initial stack pointer position defived from that. Due to a small typo, the SP position moved to 0x21f80, which is past the SRAM area. This didn't manifest on the real hardware as the SRAM repeats there (address bits in the CPU being ignored). Though this was caught in QEMU, where it crashed the emulator. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-29i.MX28: Make use of the bounce bufferMarek Vasut
This allows i.MX28 MMC host to fully utilize DMA transfers and caches, greatly improving speed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <festevam@gmail.com>
2012-03-27configs: imx: Use CONFIG_SF_DEFAULT_CSFabio Estevam
CONFIG_SPI_FLASH_CS is not used anywhere. Use CONFIG_SF_DEFAULT_CS instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-01-16M28EVK: Fix build if CONFIG_CMD_NAND not selectedMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-01-16m28evk: Use GENERATED_GBL_DATA_SIZEFabio Estevam
Use GENERATED_GBL_DATA_SIZE for calculating CONFIG_SYS_INIT_SP_OFFSET. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-09M28: Cleanup memsize.o OOT buildMarek Vasut
The current way memsize.c is built just made a symlink into the directory with SPL and then compiled it like any other file there. This was bad as that broke the out-of-tree build. The new way introduced in this patch uses the standard spl/Makefile methods (CONFIG_SPL_LIBCOMMON_SUPPORT / CONFIG_SPL_LIBGENERIC_SUPPORT) to let files in common/ be built. Because common/Makefile says memsize.c is always built (SPL and non-SPL build), this fixes our issue with memsize.c out-of-tree build. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28Marek Vasut
This moves SPL to common location so it can be reused by multiple boards. Also, this commit adjusts M28 SoM to avoid breakage due to the move. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-11-11m28evk: Fix comment about the number of RAM banksFabio Estevam
m28evk has one bank of RAM. Fix the comment. Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-11-11M28EVK: Enable USB HOST supportMarek Vasut
This enables the second port, aka. the port with the USB connector on the M28EVK. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Remy Bohmer <linux@bohmer.net>
2011-11-11M28: Add memory detection into SPLMarek Vasut
This code allows the DDR DRAM size to be detected at runtime. The RAM size is stored into two scratch registers, from which it is then fetched in U-Boot. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11iMX28: Fix ARM vector handlingMarek Vasut
This patch introduces proper ARM vector handling for i.MX28 CPU. This issue wasn't addressed because the interrupts weren't enabled on any ARMv5 core, therefore the issue wasn't noticed earlier. In previous implementation, the vectoring code used by i.MX28 CPU when an exception happened was that of the SPL. With this change, the branch target when an exception happens can be reconfigured by U-Boot. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11M28: Add MMC SPLMarek Vasut
This patch adds SPL code for the M28 board. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11iMX28: Add support for DENX M28EVK boardMarek Vasut
This contains support for the following components: - DUART - MMC - Both FEC interfaces - NAND - I2C (RTC, EEPROM) - SPI (FLASH) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
