path: root/include/configs/lwmon5.h
2014-12-08powerpc: lwmon5: remove redundant CONFIG_SPL_* definesMasahiro Yamada
The CPU directory of this board is arch/powerpc/cpu/ppc4xx. Without the CONFIG_SPL_START_S_PATH and CONFIG_SPL_LDSCRIPT defines, the same start.o and u-boot-spl.lds are selected by default. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-09-07ppc4xx: Fix GPIO handling in lwmon5 and lcd4_lwmon5 BSPStefan Roese
LCD4 needs a slightly different GPIO configuration than the original LWMON5 variant. GPIO49 needs to be configured to a default output value of 0 (permanent voltage supply). Additionally lcd4 also needs to enable the LSB transmitter. Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-04-22ppc4xx: Add lcd4_lwmon5 supportStefan Roese
This patch adds the fast booting LWMON5 derivat "lcd4_lwmon5". Its a stripped down version of the full blown lwmon5 support, without ECC, USB, POST and some other stuff. It used the newly introduced SPL infrastrucure for SPL from NOR flash booting on the PPC4xx. By setting the environment variable "boot_os" to "yes", Linux will be started from the SPL version. If not, the "normal" U-Boot will be started. Signed-off-by: Stefan Roese <sr@denx.de>
2012-11-20boards: remove the no longer used CONFIG_EHCI_DCACHEJeroen Hofstee
CONFIG_EHCI_DCACHE was removed by commit b8adb12 "USB: Drop cache flush bloat in EHCI-HCD". Remove the defines from the boards configs as well. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> cc: Marek Vasut <marex@denx.de> cc: Stefan Roese <sr@denx.de> cc: Tom Rini <trini@ti.com> cc: Wolfgang Denk <wd@denx.de> cc: Thierry Reding <thierry.reding@avionic-design.de> cc: Tom Warren <twarren@nvidia.com> cc: Stephen Warren <swarren@nvidia.com> cc: Stefano Babic <sbabic@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-04-19CMD: Remove CMD_LOG, it's unusedMarek Vasut
$ git grep CMD_LOG include/configs/kilauea.h:#define CONFIG_CMD_LOG include/configs/lwmon5.h:#define CONFIG_CMD_LOG include/configs/makalu.h:#define CONFIG_CMD_LOG include/configs/quad100hd.h:#undef CONFIG_CMD_LOG include/configs/zeus.h:#define CONFIG_CMD_LOG Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-01-10ppc4xx: Remove PCI support from lwmon5Stefan Roese
PCI is not used at all on lwmon5. So lets remove it. It saves space and reduces boot time a bit (approx. 50ms). Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-17ppc4xx: Update lwmon5 board supportStefan Roese
This patch includes the following changes for the lwmon5 board support: - Enable cache in SDRAM - Use common EHCI driver instead of the PPC4xx specific OHCI driver This can be done since only high-speed devices are connected. - Remove cached TLB entry again after ECC setup - Use correct define for cache enabling (CONFIG_4xx_DCACHE instead of CONFIG_SYS_ENABLE_SDRAM_CACHE) - Enable FIT image support Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20ppc4xx/POST: Add board specific UART POST test to lwmon5Stefan Roese
Add CONFIG_POST_UART to implement a board specific UART POST test. This is done since lwmon5 needs to set POST_ALWAYS to run this test on each reboot. And we don't want to change the default behavious of this this. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-04ppc4xx: Use common ns16550 functions in 4xx UART POST driverStefan Roese
This patch changes the PPC4xx POST UART driver to use the common NS16550 functions for receiving and sending. Additionally the local function for SoC divisor setup are removed. Instead the functions from arch/powerpc/cpu/ppc4xx/4xx_uart.c are used. This removes code duplication. Also the common CONFIG_SYS_NS16550_COMx defines are now used to describe the POST UART's. And a compile breakage is fixed, introduced by a git merge of the ppc4xx/next branch into master. Now "ppc4xx.h" is moved to "asm/ppc4xx.h". Fixed as well with this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-04ppc4xx: Big lwmon5 board support rework/updateSascha Laue
This patch brings the lwmon5 board support up-to-date. Here a summary of the changes: lwmon5 board port related: - GPIO's changed to control the LSB transmitter - Reset USB PHY's upon power-up - Enable CAN upon power-up - USB init error workaround (errata CHIP_6) - EBC: Enable burstmode and modify the timings for the GDC memory - EBC: Speed up NOR flash timings lwmon5 board POST related: - Add FPGA memory test - Add GDC memory test - DSP POST reworked - SYSMON POST: Fix handling of negative temperatures - Add output for sysmon1 POST - HW-watchdog min. time test reworked Additionally some coding-style changes were done. Signed-off-by: Sascha Laue <sascha.laue@liebherr.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-31video: mb862xx: add option VIDEO_FB_16BPP_WORD_SWAP for IPEK01Wolfgang Grandegger
In 16 bpp mode, the new IPEK01 board only requires swapping of D16 words for D32 accesses due to the diffferent connecting to the GDC bus. This patch introduces the configuration option VIDEO_FB_16BPP_WORD_SWAP, which should be set for all board using the mb862xx in 16 bpp mode. For the IPEK01, VIDEO_FB_16BPP_PIXEL_SWAP should not be set. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-10-31video: mb862xx: add option CONFIG_VIDEO_MB862xx_ACCEL for 32bpp modeAnatolij Gustschin
The new IPEK01 board can use the 32 bpp mode for the Lime graphics controller. For this mode, video accelaration does not work. This patch makes the accelaration configurable via CONFIG_VIDEO_MB862xx_ACCEL, which is enabled for the lwmon5 and the socrates board for backward compatibility. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-10-31video: mb862xx: improve board-specific Lime configurationWolfgang Grandegger
To avoid board-specific code accessing the mb862xx registers directly, the public function mb862xx_probe() has been introduced. Furthermore, the "Change of Clock Frequency" and "Set Memory I/F Mode" registers are now defined by CONFIG_SYS_MB862xx_CCF and CONFIG_SYS_MB862xx__MMR, respectively. The BSPs for the socrates and lwmon5 boards have been adapted accordingly. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-07-31Fix printf() format problems with configurable promptsWolfgang Denk
U-Boot allows for configurable prompt strings using the CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far, the assumption was that any such user defined problts would contain exactly one "%d" format specifier. But some boards did not. To allow for flexible boot prompts without adding too complex code we now allow to specify the whole list of printf() arguments in the user definition. This is powerful, but requires a responsible user who really understands what he is doing, as he needs to know for exanple which variables are available in the respective context. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-20lwmon5: enable OCM post test on lwmon5 boardYuri Tikhonov
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-04-29lwmon5: minor clean-up to include/configs/lwmon5.hYuri Tikhonov
LWMON5 DSPIC POST uses the watch-dog scratch register. So, make the CFG_DSPIC_TEST_ADDR definition more readable. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-25ppc4xx: Remove double defines in lwmon5.hStefan Roese
introduced with latest lwmon5/POST merge Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-25lwmon5: watchdog POST fixYuri Tikhonov
Use the GPT0_MASKx registers as the temporary storage for watch-dog timer POST test instead of GPT0_COMPx. The latter (GPT0_COMP1..GPT0_COMP5) are used for the log-buffer header. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
