CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Acked-by: Heiko Schocher <hs@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
Remove board-specific #ifdefs for calling misc_init_r() during
initializtion
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
CONFIG_BOOTP_MASK.
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG
when it really means just CONFIG_CMD_DIAG. There is no CMD_POST.
Clear this mess up some.
Fix LCD logo for lwmon board which got lost in the merge of 8xx and PXA LCD code
enable SNTP support in some boards.
* Adjust MIPS compiler options at run-time depending on tools version
("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new,
"-mcpu=4kc" for old tools)
* Enable MSDOS/VFAT filesystem support for LWMON board
* Clear Block Lock-Bits when erasing flash on LWMON board.
* Fix return code of "fatload" command
* Disable debugging for TQM5200 board
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
modules at CPU clock frequencies above 66 MHz.
* Optimize flash programming speed for LWMON (by another 100% :-)
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
- added support for arm925t cpu core
- added support for TI OMAP 1510 Innovator Board
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules
* Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML
mirror bit flash on TQM8xxM modules
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
* MPC823 LCD driver: Fill color map backwards, to allow for steady
display when Linux takes over
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS (this time for real).
* Add support for "bmp info" and "bmp display" commands to load
bitmap images; this can be used (for example in a "preboot"
command) to display a splash screen very quickly after poweron.
* Add support for 133 MHz clock on INCA-IP board
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
when watchdog is on
* Update baudrate in bd_info when it gets changed
* Add watchdog trigger points while waiting for serial port
(so far only 8xx -- needed on LWMON with 100ms watchdog)
* Improve command line tool to access the U-Boot's environment
(figuration of the utility, using a config file)
in POST, EEPROM shows up on 8 addresses
Add i2c commands to PM826 config
* extend I2C POST code: check for list on known addresses
to log on the console, too (like in Linux); get rid of "logstart"
* Patch by Rod Boyce, 21 Nov 2002:
fix PCMCIA on MBX8xx board
* Patch by Pierre Aubert , 21 Nov 2002
Add CFG_CPM_POST_WORD_ADDR to make the offset of the
bootmode word in DPRAM configurable
syslog mechanism; used especially for POST results.
* Patch by Klaus Heydeck, 31 Oct 2002:
Add initial support for kup4k board
