path: root/include/configs/luan.h
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-194xx: add missing CONFIG_SYS_SRAM_SIZE definitionWolfgang Denk
A number of boards define CONFIG_SYS_SRAM_BASE but fail to define CONFIG_SYS_SRAM_SIZE which is needed when cleaning up the code that prints this information with the bdinfo command. Add the missing deinitions. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-06-06ppc4xx: Unify AMCC's board config files (part 2/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-16ppc4xx: AMCC Luan uses the new boardspecific DDR2 controller setupStefan Roese
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various l* named board config files.Jon Loeliger
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-01ppc4xx: Change Luan config file to support ECCStefan Roese
With the updated 44x DDR2 driver the Luan board now supports ECC generation and checking. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-08[PATCH] Update AMCC Luan 440SP eval board supportStefan Roese
The AMCC Luan now uses the common 440SP(e) DDR SPD code for DDR inititializition. This includes DDR auto calibration and support for different DIMM modules, instead of the fixed setup used in the earlier version. This patch also enables the cache in FLASH for the startup phase of U-Boot (while running from FLASH). After relocating to SDRAM the cache is disabled again. This will speed up the boot process, especially the SDRAM setup, since there are some loops for memory testing (auto calibration). Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-07[PATCH] Update some AMCC 4xx board config files (set initrd_high)Stefan Roese
Some boards that can have more than 768MBytes of SDRAM need to set "initrd_high", so that the initrd can be accessed by the Linux kernel. Signed-off-by: Stefan Roese <sr@denx.de>
2006-08-07Add commandline history support to all AMCC eval boardsStefan Roese
Patch by Stefan Roese, 07 Aug 2006
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
