path: root/include/configs/lsxl.h
2017-02-08api: Convert to KconfigEmmanuel Vadot
Now that we have a Kconfig for the API, convert the two boards that are using this to Kconfig and remove CONFIG_API from the whitelist. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-01net: Fix NET_RANDOM_ETHADDR dependenciesMichal Simek
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to Kconfig to ensure that library is also compiled. Remove the definitions from Blackfin boards' include/configs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2015-02-12lsxl: switch from bootm to bootz for boot commandsMichael Walle
Use the bootz command to load zImages in case of any new boot scripts. Only the legacy one will still use bootm. Apart form the fact, that this will simplify the image generation process, it saves one copy of the kernel image: Common practice is to generate an uImage with a loading address of 0x8000. This uImage contains a compressed zImage, which will unpack the kernel image to the beginning of the RAM. But because there is already the compressed image the uncompressor first relocates the compressed image to a higher location. The load address is encoded into the uImage which is generated by the distributions and thus cannot be easily changed. By using the bootz command we can load the compressed image to a higher memory address and the decompressor doesn't have to reloacte the image. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-12lsxl: place the dtb below the inital ramdiskMichael Walle
The dtb was loaded at a memory address after the initial ramdisk. Thus a large ramdisk would overwrite the dtb. Move it to "ramdisk_start - 64k". 64k should be enough for the device tree blob. Also the kernel documentation arm/Booting suggests to put the dtb before the initial ramdisk. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-12lsxl: use default load addresses for legacy bootMichael Walle
The load addresses for the bootcmd_legacy script were taken from the original bootloader from Buffalo. But newer kernels are too big and the uncompressing will overwrite parts of the initial ramdisk. Therefore, we switch to the load addresses which are also used by the other boot script. Signed-off-by: Michael Walle <michael@walle.cc>
2014-10-06lsxl: convert to generic board and fix typoMichael Walle
Besides converting the LS-XHL and LS-CHLv2 to generic board, fix a typo which accidentally reverted the bootsource to 'hdd' although the default bootsource should be 'legacy'. Cc: Tom Rini <trini@ti.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Michael Walle <michael@walle.cc> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-05-25lsxl: rework boot scriptsMichael Walle
Move addresses for kernel, ramdisk and fdt blob to own variables. Add dtb blob loading to all existing boot scripts, dtb filenames were taken from vanilla kernel. Introduce new boot script bootcmd_legacy, which only loads a kernel and a ramdisk. Make this the default boot script. This should also restore the behaviour of the original bootloader. Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Michael Walle <michael@walle.cc>
2014-05-25lsxl: use 64bit for LBA48 to support 4 TB drivesMichael Walle
2014-03-28lib: rand: introduce new configs: CONFIG_LIB_RAND and CONFIG_LIB_HW_RANDPrzemyslaw Marczak
New configs: - CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c - CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand Other changes: - add CONFIG_LIB_RAND to boards configs which needs rand() - put only one rand.o dependency in lib/Makefile CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library (declared in include/common.h): - void srand(unsigned int seed) - unsigned int rand(void) - unsigned int rand_r(unsigned int *seedp) Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Michael Walle <michael@walle.cc> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kirkwood: kwbimage: refactor CONFIG_SYS_KWD_CONFIGMasahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_KWD_CONFIG and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michael Walle <michael@walle.cc> Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Dave Purdy <david.c.purdy@gmail.com> Cc: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net> Cc: Luka Perkov <luka@openwrt.org> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Siddarth Gore <gores@marvell.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Eric Cooper <ecc@cmu.edu> Cc: Suriyan Ramasami <suriyan.r@gmail.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-09lsxl: unset ncip for rescue modeMichael Walle
Instead of using the serverip we get from the DHCP server, implicitly use the broadcast address, which is automatically set when no ncip environment variable is set. That way it isn't necessary to use a special DHCP configuration to set the netconsole peer. Signed-off-by: Michael Walle <michael@walle.cc> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-07-07Kirkwood: add lschlv2 and lsxhl board supportMichael Walle
This patch adds support for both the Linkstation Live (LS-CHLv2) and Linkstation Pro (LS-XHL) by Buffalo. Signed-off-by: Michael Walle <michael@walle.cc> Cc: Prafulla Wadaskar <prafulla@marvell.com>
