path: root/include/configs/ls2080aqds.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-10armv8: ls2080aqds: Enable QSPI boot supportYuan Yao
This patch adds QSPI boot support for LS2080AQDS board. The QSPI boot image need to be programmed into the QSPI flash first. Then we can switch to booting from QSPI memory space. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-10configs: ls2080a: Increase load image len in NAND bootYuan Yao
2016-06-10armv8: ls2080aqds: Config QSPI pin mux via FPGA in NAND bootYuan Yao
2016-06-10configs: ls2080aqds: Enable QSPI flash supportYuan Yao
Enable QSPI flash related configure options. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-10armv8: ls2080aqds: disable IFC NOR & QIXIS when QSPI enableYuan Yao
When QSPI is enabled, NOR flash and QIXIS can't be accessed through IFC due to pin mux. Enable I2C QIXIS access and I2C early init to read the sysclk and ddrclk. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-05-18armv8: ls2080a: update eth primePrabhakar Kushwaha
As per new PHY framework, DPNI naming convetion is no more used. Use new naming convention. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-29armv8: ls2080rdb: ls2080qds: Add secure boot supportSaksham Jain
Sec_init has been called at the beginning to initialize SEC Block (CAAM) which is used by secure boot validation later for both ls2080a qds and rdb. 64-bit address in ESBC Header has been enabled. Secure boot defconfigs are created for boards (NOR boot). Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24armv8: ls2080: Add mcinitcmd env variable in default envPrabhakar Kushwaha
Define mcinitcmd env variable to load Management complex during u-boot boot sequence. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-01board: ls2085aqds: Update kernel_size env variablePrabhakar Kushwaha
kernel_size env variable is defined as 0x28000000, it is beyond NOR flash range. Update kernel_size with 40MB kernel size. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-12-15armv8: Add sata support on Layerscape ARMv8 boardTang Yuantian
Freescale ARM-based Layerscape contains a SATA controller which comply with the serial ATA 3.0 specification and the AHCI 1.3 specification. This patch adds SATA feature on ls2080aqds, ls2080ardb and ls1043aqds boards. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
