path: root/include/configs/ls2080a_simu.h
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-03-29drivers: i2c: mxc: Update SYS_I2C_MXC_I2C support in KconfigSriram Dash
NXP layerscape platforms like ls1088a, ls2088a uses MXC I2C Controller. -Remove dependency of MX6 for the same. Update related configs to use Kconfig file. -Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig -Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig -Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06README: Drop unused CONFIG_SYS_LS_MC_FW_... optionsSimon Glass
Drop a few that are not used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-10configs: ls2080a_common: Remove duplicate NOR configsYuan Yao
The NOR flash related configure options appear in ls2080aqds.h and ls2080ardb.h, and the two files both includ ls2080a_common.h. This patch remove the duplicated options in ls2080a_common.h. Signed-off-by: Yuan Yao <yao.yuan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-06armv8: LS2080A: Consolidate LS2080A and LS2085AYork Sun
LS2080A is the primary SoC, and LS2085A is a personality with AIOP and DPAA DDR. The RDB and QDS boards support both personality. By detecting the SVR at runtime, a single image per board can support both SoCs. It gives users flexibility to swtich SoC without the need to reprogram the board. Signed-off-by: York Sun <york.sun@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
