When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
NXP layerscape platforms like ls1088a, ls2088a
uses MXC I2C Controller.
-Remove dependency of MX6 for the same.
Update related configs to use Kconfig file.
-Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig
-Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig
-Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
Reviewed-by: York Sun <york.sun@nxp.com>
Again the image size increases and the length needs to be adjusted.
Signed-off-by: York Sun <york.sun@nxp.com>
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be
equal to CONFIG_SYS_CBSIZE in numerous configuration files.
We remove such definitions in two situations:
- CONFIG_SYS_CBSIZE is otherwise not defined in the board
configuration file, which means the default value of
CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is
larger.
- CONFIG_SYS_CBSIZE is defined in the board configuration file, but
to a value equal or less than 512. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it
is equal or larger.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
With the hierarchical defaults set up, we remove these from the header
files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits
the changes.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Increase env sector size from 64kb to 256kb for qspi boot.
Signed-off-by: Santan Kumar <santan.kumar@nxp.com>
CONFIG_ENV_IS_IN_SPI_FLASH
We should not have an arch-specific header file in common.h. Adjust the
board files a little so it is not needed, and drop it.
Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com>
Add CONFIG_NAND_BOOT config flag to organise
NAND_BOOT specific code in config flag like
-nand-boot specfic errata errata_rcw_src()
-CONFIG_SYS_NAND_U_BOOT_DST,etc
DPAA2 platforms boot the Management Complex based on the u-boot env
variable "mcinitcmd". Instead of doing this step on each platform
individually, define a single mc_env_boot function in the MC driver,
since it's semantically tied to it.
Call the function in a per-board reset_phy hook, as it gets called at a
later moment, when all board PHY devices have been initialized.
Signed-off-by: Bogdan Purcareata <bogdan.purcareata@nxp.com>
Signed-off-by: Heinz Wrobel <heinz.wrobel@nxp.com>
This patch adjusts memory map for images on LS2080ARDB and
LS2080AQDS NOR flash as below
Image Flash Offset
RCW+PBI 0x00000000
Boot firmware (U-Boot) 0x00100000
Boot firmware Environment 0x00300000
PPA firmware 0x00400000
PHY firmware 0x00980000
DPAA2 MC 0x00A00000
DPAA2 DPL 0x00D00000
DPAA2 DPC 0x00E00000
Kernel.itb 0x01000000
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC.
LS2088ARDB RevF Board has limitation that QIXIS can not be accessed.
CONFIG_FSL_QIXIS is not enabled.
Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com>
CONFIG_CMD_HASH
[trini: Rework slightly, enable on some boards again]
This option is not used in U-Boot. Drop it.
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support
using hardware acceleration.") created entries for CONFIG_SHA1,
CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL.
However, no defconfig has migrated to it. Complete the move by first
adding additional logic to various Kconfig files to select this when
required and then use the moveconfig tool. In many cases we can select
these because they are required to implement other drivers. We also
correct how we include the various hashing algorithms in SPL.
This commit was generated as follows (after Kconfig additions):
[1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL
[2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL
Note:
We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously
because there is dependency between them.
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
The stream ID allocation for Chasis 3.0 devices can be shared among
LS1088, LS2088 and LS2080.
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@nxp.com>
Move this in to Kconfig with a default of 115200.
[trini: Run moveconfig.py, reword commit slightly]
Use Kconfig option instead of config macro in header file.
Clean up existing usage.
In some cases this is absolutely required, so select this for some secure
features. This also requires migration of RSA_FREESCALE_EXP
Cc: Ruchika Gupta <ruchika.gupta@nxp.com>
Cc: Saksham Jain <saksham.jain@nxp.freescale.com>
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
CONFIG_ARCH_EARLY_INIT_R
This patch binds the sys_info->freq_systembus to Platform PLL, and
implements the IPs' clock function individually.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
The patch enables PCIe in ls2080a defconfigs and
removes unused PCIe related macro defines.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
in certain architectures. Migrate all config files.
Move DDR3, DDR4 and realted options to Kconfig and clean up existing
uses.
Move these options to Kconfig and clean up existing uses.
Move these options to Kconfig and create a sub-menu to avoid name
conflict with other architectures.
trini: Drop local memset() from
examples/standalone/mem_to_mem_idma2intr.c
Move this option to Kconfig and tidy up existing uses.
