CONFIG_SCSI_AHCI_PLAT
CONFIG_SYS_SCSI_MAX_SCSI_ID
CONFIG_SYS_SCSI_MAX_LUN
CONFIG_SYS_SATA_MAX_DEVICE
Drop CONFIG_SCSI for everything except the sandbox build. We only need
one build for tests.
This is defined based on two other CONFIGs for all boards except sandbox
and durian.
For sandbox the value does not matter. For durian the value seems
excessive.
Drop the option completely, to simplify configuration and reduce the
number of things we need to convert to Kconfig.
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_FSL_IFC
This is done via select statements to match previous logic.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SPL_DRIVERS_MISC
CONFIG_SPL_ENV_SUPPORT
CONFIG_SPL_GPIO
CONFIG_SPL_I2C
CONFIG_SPL_LDSCRIPT
CONFIG_SPL_LIBCOMMON_SUPPORT
CONFIG_SPL_LIBGENERIC_SUPPORT
CONFIG_SPL_LOAD_FIT_ADDRESS
CONFIG_SPL_MMC
CONFIG_SPL_NAND_SUPPORT
CONFIG_SPL_NO_CPU_SUPPORT
CONFIG_SPL_OS_BOOT
CONFIG_SPL_POWER
CONFIG_SPL_STACK_R
CONFIG_SPL_STACK_R_ADDR
CONFIG_SPL_WATCHDOG
CONFIG_SPL_TEXT_BASE
A number of platforms are still defining CONFIG_SYS_BAUDRATE_TABLE to
the fallback default of "{ 9600, 19200, 38400, 57600, 115200 }", but
with varying whitespace, or were introduced after the default fallback
was added. Use the default table here.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
Use CONFIG_IS_ENABLED() macro, which provides more convenient
way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs
for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to:
- 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y',
- 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y',
- 0 otherwise.
All occurences were replaced automatically using these bash cmds:
$ find . -type f -exec sed -i
's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CONFIG_MPC8XXX_GPIO for LS1088A
Signed-off-by: Biwen Li <biwen.li@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
The generic armv8 code already has support to bring up the secondary
cores. Thus, don't hardcode the jump in the layerscape lowlevel_init to
the spin table code; instead just return early and let the common armv8
code handle the jump. This way we can actually use the CPU_RELEASE_ADDR
feature.
Signed-off-by: Michael Walle <michael@walle.cc>
[Rebased, Removed kontron_sl28.h change as file does not exist]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_BAUDRATE
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
Some of these options are not used by the driver anymore and some of
them are obsolete as the information is gathered from the dt. Also
consolidating defines in common headers.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict
with UEFI secure boot.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM
I2C API when DM_I2C is used.When DM_I2C_COMPAT is not enabled for
compilation, a compilation error will be generated. This patch
solves the problem that the i2c-related api of the ls1088a platform
does not support dm.
Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
ls2088, ls1088 : minimum MC Memory size is 128 MB
lx2 : minimum MC memory size is 256 MB
Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com>
Moves below DDR specific defines to Kconfig:
CONFIG_FSL_DDR_BIST
CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE
CONFIG_FSL_DDR_INTERACTIVE
CONFIG_FSL_DDR_SYNC_REFRESH
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Moves CONFIG_LAYERSCAPE for all NXP Layerscape platforms.
TFABOOT support includes:
- ls1088ardb_tfa_defconfig to be loaded by trusted firmware
- environment address and size changes for TFABOOT
- MC address changes for TFABOOT
- define BOOTCOMMAND for TFABOOT
- ifc chip select changes for TFABOOT
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
ls1088ardb-pb and ls1088ardb both boards are ls1088a based soc,
board type detection is dynamic at boot time
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
This patch reverts the changes made for ls1088a and ls2080a
based boards in commit 18b6dd6cb0564 ("armv8: layerscape: Drop
u-boot-with-spl.bin for selected boards").
u-boot-with-spl.bin is required for Gen3 based SoC where internal
ROM copy data in the internal memory
CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
CC: Priyanka Jain <priyanka.jain@nxp.com>
CC: Pramod Kumar <pramod.kumar_1@nxp.com>
CC: Ashish Kumar <ashish.kumar@nxp.com>
CC: York Sun <york.sun@nxp.com>
Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
For SPL boot with PBL, u-boot-with-spl-pbl.bin is the final image.
Drop unused u-boot-with-spl.bin.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Mingkai Hu <mingkai.hu@nxp.com>
CC: Ruchika Gupta <ruchika.gupta@nxp.com>
CC: Udit Agarwal <udit.agarwal@nxp.com>
CC: Sumit Garg <sumit.garg@nxp.com>
use "fsl_mc lazyapply dpl addr" instead of "fsl_mc apply dpl addr"
change dpl load addr to 0x80001000 from 0x80200000 because dpl gets
corrupted at 0x80200000 during bootm command excecution.
There is no reason to define default option for this macro which is
already done in common/cli_hush.c.
86 #ifndef CONFIG_SYS_PROMPT_HUSH_PS2
87 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
88 #endif
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
NXP layerscape platforms like ls1088a, ls2088a
uses MXC I2C Controller.
-Remove dependency of MX6 for the same.
Update related configs to use Kconfig file.
-Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig
-Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig
-Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
[YS: run moveconfig.py -s]
Using changes in this patch we were able to reduce approx 8k
size of u-boot-spl.bin image. Following is breif description of
changes to reduce SPL size:
1. Changes in board/freescale/ls1088a/Makefile to remove
compilation of eth.c and cpld.c in case of SPL build.
2. Changes in board/freescale/ls1088a/ls1088a.c to keep
board_early_init_f funcations in case of SPL build.
3. Changes in ls1088a_common.h & ls1088ardb.h to remove driver
specific macros due to which static data was being compiled in
case of SPL build.
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
This symbol enables some library code used by various SATA drivers,
so make this a non-user-visible symbol select'ed by the respective
drivers, and let moveconfig handle the rest.
And use 'imply' liberally.
Validates PPA, MC, DPC, Bootscript, DPL and Kernel images in ESBC
phase using esbc_validate command.
Enable validation of boot.scr script prior to its execution dependent
on "secureboot" flag in environment
Add header address for PPA to be validated during ESBC phase for
LS1088A platform based on LAyerscape Chasis 3.
Moves sec_init prior to ppa_init as for validation of PPA sec must
be initialised before the PPA is initialised.
Signed-off-by: Vinitha Pillai-B57223 <vinitha.pillai@nxp.com>
