path: root/include/configs/ls1046a_common.h
2019-06-19armv8: ls1046afrwy: Add support for LS1046AFRWY platformVabhav Sharma
LS1046AFRWY board supports LS1046A family SoCs. This patch add base support for this board. Board support's 4GB ddr memory, i2c, micro-click module,microSD card, serial console,qspi nor flash,ifc nand flash,qsgmii network interface, usb 3.0 and serdes interface to support two x1gen3 pcie interface. Signed-off-by: Camelia Groza <camelia.groza@nxp.com> Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-22armv8: Secure Boot: Modify boot_a_script definitionVinitha V Pillai
esbc_validate command will not be executed if “load” command for its header fails and will further execute the source command for bootscript, without its validation and boot process continues. To halt the boot process in case secure boot header is not loaded successfully, esbc_validate command is invoked separately after “load” command. The secure boot validation of the bootscript header will fail (if header is not loaded) and halts the boot process, which prevent source command from execution. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-03board: ls1046a: use default scan_dev_for_bootMian Yousaf Kaukab
Default environment variable is more complete. Also scans for efi binaries for example. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-03board: ls1046a: enable dhcp bootMian Yousaf Kaukab
dhcp boot is a useful feature and works out-of-the-box on these platforms. Enable it as a boot source. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19armv8: layerscape: move CONFIG_LAYERSCAPE to KconfigRajesh Bhagat
Moves CONFIG_LAYERSCAPE for all NXP Layerscape platforms. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-12-06armv8: ls1046ardb: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1046ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - FMAN address changes for TFABOOT - define BOOTCOMMAND for TFABOOT Signed-off-by: York Sun <york.sun@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2018-07-26armv8: ls1046ardb: Add falcon mode for for QSPI bootYork Sun
A new defconfig is introduced to support SPL boot from QSPI NOR flash. This is to support falcon mode for faster booting into Linux. Signed-off-by: York Sun <york.sun@nxp.com>
2018-07-26armv8: layerscape: Drop u-boot-with-spl.bin for selected boardsYork Sun
For SPL boot with PBL, u-boot-with-spl-pbl.bin is the final image. Drop unused u-boot-with-spl.bin. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mingkai Hu <mingkai.hu@nxp.com> CC: Ruchika Gupta <ruchika.gupta@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> CC: Udit Agarwal <udit.agarwal@nxp.com> CC: Sumit Garg <sumit.garg@nxp.com> CC: Priyanka Jain <priyanka.jain@nxp.com>
2018-07-26armv8: ls1046ardb: Enable IFC for SPL buildYork Sun
Commit a52ff334c5b1 ("armv8: ls1046ardb: SPL size reduction") reduced image size for SPL. IFC was disabled. If PPA is loaded in SPL, MMU is enabled as a result. Removing IFC skips IFC region in the MMU table, causing later failure in RAM version U-boot when accessing CPLD through IFC. Only disable IFC if PPA is not enabled for SPL. Signed-off-by: York Sun <york.sun@nxp.com>
2018-07-26armv8: ls1046ardb: ls1046aqds: Move SPL macros to defconfigYork Sun
Instead of defining Kconfig macros in header file, move them to defconfig files. Signed-off-by: York Sun <york.sun@nxp.com>
2018-04-28Cleanup CONFIG_SPL_SERIAL_SUPPORT migrationAlex Kiernan
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but existed in some include files; fix those up here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-03-29drivers: i2c: mxc: Update SYS_I2C_MXC_I2C support in KconfigSriram Dash
NXP layerscape platforms like ls1088a, ls2088a uses MXC I2C Controller. -Remove dependency of MX6 for the same. Update related configs to use Kconfig file. -Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig -Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig -Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-17arm64: ls1046a: Add sata distro boot supportYuantian Tang
Sata is equipped on ls1046a and can be a boot source. Add sata boot support as an option if available. Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-10configs: Move SYS_DPAA_QBMAN to KconfigAhmed Mansour
The CONFIG_SYS_DPAA_QBMAN define is used by DPAA1 freescale SOCs to add device tree fixups that allow deep sleep in Linux. The define was placed in header files included by a number of boards, but was not explicitly documented in any of the Kconfigs. A description was added to the drivers/networking menuconfig and default selection for current SOCs that have this part Signed-off-by: Ahmed Mansour <ahmed.mansour@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-06SECURE BOOT: Add fall back optionVinitha Pillai-B57223
Add fall back option, to boot from NOR/QSPI/SD for LS1043, LS1046, LS1021 in case of distro boot failure. For LS1046, add kernel validation in case of secure boot in sd_bootcmd and qspi_bootcmd. For LS1043 and LS1021, add kernel validation in case of secure boot in sd_bootcmd, qspi_bootcmdand nor_bootcmd. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-15armv8: ls1046ardb: Add sd_bootcmd for distro fallback in case of sdbootShengzhou Liu
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-09armv8: ls1046aqds: Fix NAND offset for Fman ucode and envGong Qianyu
Fix a bug of 'commit 8104deb2d6b7 ("armv8: layerscape: Adjust memory mapping for Flash/SD card on LS1046A")' as NAND block size is 256KB on LS1046AQDS. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01arm64: ls1046ardb: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm64: ls1046ardb: Add distro boot supportQianyu Gong
Tested on ls1046ardb with automatically boot Ubuntu from SD card or USB disk, if it fails to detect external storage disk, fall back to qspi boot. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-05common: arm: freescale: layerscape: Move header files out of common.hSimon Glass
We should not have an arch-specific header file in common.h. Adjust the board files a little so it is not needed, and drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-05-23armv8: layerscape: Adjust memory mapping for Flash/SD card on LS1046AAlison Wang
This patch is to adjust the memory mapping for FLash/SD card on LS1046AQDS and LS1046ARDB, such as FMAN firmware load address, U-Boot start address on serial flash and environment address. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls1046a: enable PCI command toolHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-17arm: ls1046ardb: Add SD secure boot targetRuchika Gupta
- Add SD secure boot target for ls1046ardb. - Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. - CONFIG_MAX_SPL_SIZE is limited to 90KB. SPL is copied to OCRAM (128K) where 32K are reserved for use by boot ROM and 6K for the header. - Reduce the size of CAAM driver for SPL Blobification functions and descriptors, that are not required at the time of SPL are disabled. Further error code conversion to strings is disabled for SPL build. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17armv8: ls1046ardb: SPL size reductionSumit Garg
Using changes in this patch we were able to reduce approx 4k size of u-boot-spl.bin image. Following is breif description of changes to reduce SPL size: 1. Changes in board/freescale/ls1046ardb/Makefile to remove compilation of eth.c and cpld.c in case of SPL build. 2. Changes in board/freescale/ls1046ardb/ls1046ardb.c to keep only ddr_init and board_early_init_f funcations in case of SPL build. 3. Changes in ls1046a_common.h & ls1046ardb.h to remove driver specific macros due to which static data was being compiled in case of SPL build. 4. Disable MMC driver from bieng compiled in case of SPL NAND build and NAND driver from bieng compiled in case of SPL MMC build. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-28armv8: fsl-lsch2: Use Chassis-2 streamid definition for ls1046aBharat Bhushan
LS1046A is Chassis-2 type SOC and shares same streamid definition, this patch adds using streamids for LS1046A. Signed-off-by: Bharat Bhushan <Bharat.Bhushan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
