To work around distro boot issue caused by the EFI boot process
change (refer to LFU-189), add a 'fdt_addr' env pointing to
a DRAM address, in which there isn't valid DTB, to let bootefi
get invalid DTB and then skip EFI boot.
This is a workaround patch, remove it when the EFI boot feature
has been supported or the U-Boot DTB has been modified to
compatibile with Linux.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
On Layerscape platforms, the DTB is loaded from boot filesystem,
per the fdt_addr description in doc/README.distro, it must be
removed.
And on many platforms, like ls1046a, ls1088a, ls2088a and lx216xa,
the 'fdt_addr' pointed address is not accessible.
And with the current EFI boot process, since the EFI_LOADER and
CMD_BOOTEFI_BOOTMGR are enabled by default, if the EFI boot
components are not deployed in the boot filesystem, it will try
to get DTB at address 'fdt_addr' and then result in "SError" or
"Synchronous Abort":
Error log on ls1046ardb:
=> run distro_bootcmd
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk esdhc@1560000.blk...
Found 5 disks
No EFI system partition
"Error" handler, esr 0xbf000000
elr: 00000000820704f4 lr : 00000000820080d4 (reloc)
elr: 00000000fbd914f4 lr : 00000000fbd290d4
x0 : 0000000064f00000 x1 : 00000000edfe0dd0
x2 : 0000000000000000 x3 : 0000000000000000
x4 : 00000000fbc2ee1a x5 : 000000000000000f
x6 : 0000000000000000 x7 : 0000000000000008
x8 : 0000000000000010 x9 : 0000000000000008
x10: 0000000000000044 x11: 00000008ffff0220
x12: 00000000fbdaa748 x13: 00000000fbda70f8
x14: 00000000fbd21d20 x15: 00000000fbc194e8
x16: 00000000fbd70fc8 x17: 0000000000000000
x18: 00000000fbc1cdb0 x19: 00000000fbd21bf0
x20: 0000000064f00000 x21: 00000000fbda6fb8
x22: 0000000000000018 x23: 0000000000000018
x24: 00000000fbde6344 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000fbc53660 x29: 00000000fbc19220
Code: 7a419060 1a9f3000 a8c17bfd d65f03c0 (12800100)
Resetting CPU ...
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
CONFIG_CONS_INDEX
CONFIG_DEBUG_UART_CLOCK
CONFIG_FSL_TZPC_BP147
CONFIG_GENERIC_ATMEL_MCI
CONFIG_IDENT_STRING
CONFIG_LIBATA
CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE
CONFIG_LPC32XX_GPIO
CONFIG_MP
CONFIG_MPC8XXX_GPIO
CONFIG_MTD_PARTITIONS
CONFIG_MVGBE
CONFIG_MXC_GPIO
CONFIG_NR_DRAM_BANKS
CONFIG_OF_BOARD_SETUP
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_OF_SYSTEM_SETUP
CONFIG_PREBOOT
CONFIG_ROCKCHIP_SERIAL
CONFIG_RTC_ENABLE_32KHZ_OUTPUT
CONFIG_RTC_MV
CONFIG_SCSI_AHCI
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_SPEED
CONFIG_SOFT_SPI
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_MTD
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_STMICRO
CONFIG_SUPPORT_RAW_INITRD
CONFIG_SYS_ARCH_TIMER
CONFIG_SYS_BOARD
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_DCACHE_OFF
CONFIG_SYS_FDT_SAVE_ADDRESS
CONFIG_SYS_FLASH_CFI
CONFIG_SYS_FSL_ERRATUM_ESDHC135
CONFIG_SYS_HAS_SERDES
CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_LITTLE_ENDIAN
CONFIG_SYS_LOAD_ADDR
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
CONFIG_SYS_NS16550
CONFIG_SYS_PLLFIN
CONFIG_SYS_SPI_U_BOOT_OFFS
CONFIG_TIMER_SYS_TICK_CH
CONFIG_USB_EHCI_FSL
CONFIG_U_QE
CONFIG_VERSION_VARIABLE
CONFIG_FSL_IFC
This is done via select statements to match previous logic.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Use moveconfig.py script to convert CONFIG_SYS_FMAN_FW_ADDR,
CONFIG_SYS_QE_FW_ADDR and CONFIG_SYS_QE_FMAN_FW_LENGTH to Kconfig and
move these entries to defconfigs.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_SPL_NAND_LOAD
CONFIG_SYS_NAND_BLOCK_SIZE
CONFIG_SYS_NAND_PAGE_SIZE
CONFIG_SYS_NAND_OOBSIZE
A number of platforms are still defining CONFIG_SYS_BAUDRATE_TABLE to
the fallback default of "{ 9600, 19200, 38400, 57600, 115200 }", but
with varying whitespace, or were introduced after the default fallback
was added. Use the default table here.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Migrate CONFIG_GICV2 and CONFIG_GICV3 to Kconfig. We still have the GIC
related registers that need to be handled more cleanly but start by
moving this symbol to Kconfig.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
Drop CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33. CONFIG_FSL_ESDHC_VS33_NOT_SUPPORT
is used instead.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Acked-by: Michael Walle <michael@walle.cc> [for kontron-sl28]
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Use CONFIG_IS_ENABLED() macro, which provides more convenient
way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs
for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to:
- 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y',
- 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y',
- 0 otherwise.
All occurences were replaced automatically using these bash cmds:
$ find . -type f -exec sed -i
's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Enable CONFIG_MPC8XXX_GPIO for SoC LS1043A
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Update kernelheader_addr and kernelheader_addr variables with
correct values for ls1043a.
Signed-off-by: Manish Tomar <manish.tomar@nxp.com>
This enables SYS_I2C_MXC to fix a bug that
failed to boot from sd card with
image u-boot-with-spl-pbl.bin
The generic armv8 code already has support to bring up the secondary
cores. Thus, don't hardcode the jump in the layerscape lowlevel_init to
the spin table code; instead just return early and let the common armv8
code handle the jump. This way we can actually use the CPU_RELEASE_ADDR
feature.
Signed-off-by: Michael Walle <michael@walle.cc>
[Rebased, Removed kontron_sl28.h change as file does not exist]
This patch fixes issue with defining the DM_SPI_FLASH in the
configs/include/<board.h> instead of enabling this option in Kconfig.
The problem is that CONFIG_IS_ENABLED(DM_SPI_FLASH) shows false as there
is no DM_SPI_FLASH=y in .config (but the define is set in u-boot.cfg).
As a result conversion of DM_SPI_FLASH to using CONFIG_IS_ENABLED() is not
working properly.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
This supports i2c DM and enables CONFIG_DM_I2C
for SoC LS1043A
Fix the kernel offset of qspi_bootcmd scripts, followed
the qoriq_memory_layout definition.
Signed-off-by: Wen He <wen.he_1@nxp.com>
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict
with UEFI secure boot.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
esbc_validate command will not be executed if “load” command for its
header fails and will further execute the source command for bootscript,
without its validation and boot process continues.
To halt the boot process in case secure boot header is not loaded
successfully, esbc_validate command is invoked separately after “load”
command. The secure boot validation of the bootscript header will fail
(if header is not loaded) and halts the boot process, which prevent source
command from execution.
Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_SF_DEFAULT_MODE
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Default environment variable is more complete. Also scans for efi
binaries for example.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
Reviewed-by: Ashish Kumar <Ashish.Kumar@nxp.com>
dhcp boot is a useful feature and works out-of-the-box on these
platforms. Enable it as a boot source.
Moves CONFIG_LAYERSCAPE for all NXP Layerscape platforms.
Due to the new layout of Layerscape series, move the QE
firmware to address (512*4A00) in SD Card.
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
nand_bootcmd doest not exist, it should be support
for nand auto boot up.
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
TFABOOT support includes:
- ls1043ardb_tfa_defconfig to be loaded by trusted firmware
- environment address and size changes for TFABOOT
- FMAN and QE address changes for TFABOOT
- define BOOTCOMMAND for TFABOOT
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
[trini: Re-migrate]
For SPL boot with PBL, u-boot-with-spl-pbl.bin is the final image.
Drop unused u-boot-with-spl.bin.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Mingkai Hu <mingkai.hu@nxp.com>
CC: Ruchika Gupta <ruchika.gupta@nxp.com>
CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
CC: Udit Agarwal <udit.agarwal@nxp.com>
CC: Sumit Garg <sumit.garg@nxp.com>
CC: Priyanka Jain <priyanka.jain@nxp.com>
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
NXP layerscape platforms like ls1088a, ls2088a
uses MXC I2C Controller.
-Remove dependency of MX6 for the same.
Update related configs to use Kconfig file.
-Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig
-Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig
-Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
With the contents of config_distro_defaults.h migrated to Kconfig,
we can remove this header file completely
