path: root/include/configs/ls1043a_common.h
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
2016-08-02armv8: ls1043a: enable pxe commandsWenbin Song
Enable pxe command for ls1043ardb and ls1043aqds. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26armv8/ls1043a: Add MTD partition schemeWenbin Song
Add and share the the MTD partition scheme with kernel by default bootargs. And add the "mtdparts" env. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26ARMv8/ls1046a: Cleanup the environment variablesWenbin Song
Cleanup the variables: "kernel_addr","ramdisk_addr", "ramdisk_size","console". Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-18armv8: ls1043a: copy kernel from QSPI when booting with QSPI enabledQianyu Gong
IFC won't be initialized in U-Boot if QSPI is enabled on LS1043AQDS. So this patch could fix 'sync abort' caused by autoboot that tries to access IFC address. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-04-06armv8: ls1043a: load Fman ucode from SD/MMC under SD bootQianyu Gong
2016-04-06armv8: ls1043a: load Fman ucode from NAND flash under NAND bootQianyu Gong
2016-03-24armv8/ls1043a: Update env settings for booting kernelQianyu Gong
2016-01-27armv8/ls1043aqds: add QSPI boot supportQianyu Gong
Enable the U-Boot Driver Model(DM) to use the Freescale QSPI driver. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: add QSPI support in SD bootGong Qianyu
QSPI and IFC are pin-multiplexed on LS1043A. So we use ls1043aqds_sdcard_ifc_defconfig to support IFC in SD boot and ls1043aqds_sdcard_qspi_defconfig to support QSPI in SD boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: add DSPI supportGong Qianyu
Enable three DSPI flash memories on board. Commands: => sf probe 1:0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB => sf probe 1:1 SF: Detected SST25WF040B with page size 256 Bytes, erase size 4 KiB, total 512 KiB => sf probe 1:2 SF: Detected EN25S64 with page size 256 Bytes, erase size 64 KiB, total 8 MiB Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: include/configs: make secure boot header file uniformAneesh Bansal
The file fsl_secure_boot.h must be included in config file for Secure Boot. This is not required to be protected by any macro. CONFIG_FSL_CAAM must be defined and CONFIG_CMD_HASH should be turned on. The above was missing in some config files and all files have been made uniform in this respect. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-12-13armv8/ls1043ardb: Add support for >2GB memoryShaohui Xie
This patch also expose the complete DDR region(s) to Linux. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043a: Enable secondary coresHou Zhiqiang
After the secondary cores enter U-Boot, use CONFIG_ARMV8_MULTIENTRY to make secondary cores excute in spin loop. Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add sd boot supportGong Qianyu
2015-10-29armv8/ls1043ardb: esdhc: Add esdhc support for ls1043ardbYangbo Lu
This patch adds esdhc support for ls1043ardb. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043a: Add Fman supportShaohui Xie
Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add nand boot supportGong Qianyu
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add LS1043ARDB board supportMingkai Hu
LS1043ARDB Specification: ------------------------- Memory subsystem: * 2GByte DDR4 SDRAM (32bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * XFI 10G port * QSGMII with 4x 1G ports * Two RGMII ports PCIe: * PCIe2 (Lanes C) to mini-PCIe slot * PCIe3 (Lanes D) to PCIe slot USB 3.0: two super speed USB 3.0 type A ports UART: supports two UARTs up to 115200 bps for console Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
