path: root/include/configs/ls1021atwr.h
2020-05-19treewide: Remove unused FSL QSPI config options for Layerscape platformsKuldeep Singh
Some of these options are not used by the driver anymore and some of them are obsolete as the information is gathered from the dt. Also consolidating defines in common headers. Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: ls1021a: Append CMA configuration to bootargsAlison Wang
The default reserved memory for CMA is high memory. If LPAE is enabled, highmem pages are non-remapped and can not be used with dma_alloc_coherent. Reserving low memory for CMA is needed for LS1021A. This patch appends the related CMA configuration to bootargs. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-03-30configs: ls1021a: Append othbootargs to bootargsAlison Wang
This patch appends othbootargs to bootargs for LS1021ATWR board. Signed-off-by: Alison Wang <alison.wang@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-03-30ls1021a: Set CONFIG_SYS_BOOTMAPSZ to the memory for relocationAlison Wang
This patch sets CONFIG_SYS_BOOTMAPSZ to the amount of memory available to safely contain a kernel, device tree and initrd for relocation. The way to set fdt_high as 0xffffffff to disable device tree relocation is removed. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04configs: ls1021a: Reserve low memory for CMAAlison Wang
The default reserved memory for CMA is high memory. If LPAE is enabled, highmem pages are non-remapped and can not be used with dma_alloc_coherent. This patch will reserve low memory for CMA and fix the issue on LS1021A. Signed-off-by: Peng Ma <peng.ma@nxp.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-07-25configs: ls1021atwr: Fix distro_bootcmd for QSPI bootVladimir Oltean
Due to a typo, "run qspi_bootcmd" and "env exists secureboot" got concatenated instead of being separated by a semicolon. Signed-off-by: Vladimir Oltean <olteanv@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-07-25arm: ls1021atwr: Convert to use driver model TSEC driverBin Meng
Now that we have added driver model support to the TSEC driver, convert ls1021atwr board to use it. This depends on previous DM series for ls1021atwr: http://patchwork.ozlabs.org/patch/561855/ Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Vladimir Oltean <olteanv@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [Vladimir] Made the following changes: - Added 'status = "disabled";' for all Ethernet ports in ls1021a.dtsi - Fixed the confusion between the SGMII/TBI PCS for enet0 and enet1 - a mistake ported over from Linux. Each SGMII PCS lies on the private MDIO bus of the interface (and the RGMII enet2 has no SGMII PCS). - Added CONFIG_DM_ETH to all ls1021atwr_* defconfigs - Completely removed non-DM_ETH support from ls1021atwr - Changed "compatible" string from "fsl,tsec-mdio" to "fsl,etsec2-mdio" and from "fsl,tsec" to "fsl,etsec2" to match Linux
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-22armv8: Secure Boot: Modify boot_a_script definitionVinitha V Pillai
esbc_validate command will not be executed if “load” command for its header fails and will further execute the source command for bootscript, without its validation and boot process continues. To halt the boot process in case secure boot header is not loaded successfully, esbc_validate command is invoked separately after “load” command. The secure boot validation of the bootscript header will fail (if header is not loaded) and halts the boot process, which prevent source command from execution. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-15armv7: ls102xa: Add workaround for DDR erratum A-008850Alison Wang
Barrier transactions from CCI400 need to be disabled till the DDR is configured, otherwise it may lead to system hang. The patch adds workaround to fix the erratum. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-03board: Enable DHCP distro boot for LS1012a, LS1021aYunfeng Ding
Enable DHCP distro boot for Layerscape LS1012A and LS1021A. Signed-off-by: Yunfeng Ding <yunfeng.ding@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-09-27drivers: qe: Move CONFIG_U_QE to KconfigRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> [York S: revised subject line and removed commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-09arm64: layerscape: Move CONFIG_HAS_FSL_DR_USB to KconfigRan Wang
Rename to USB_EHCI_FSL, use Kconfig to select ehci accordingly. Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
2017-12-06SECURE BOOT: Add fall back optionVinitha Pillai-B57223
Add fall back option, to boot from NOR/QSPI/SD for LS1043, LS1046, LS1021 in case of distro boot failure. For LS1046, add kernel validation in case of secure boot in sd_bootcmd and qspi_bootcmd. For LS1043 and LS1021, add kernel validation in case of secure boot in sd_bootcmd, qspi_bootcmdand nor_bootcmd. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-15armv7: ls1021atwr: Add sd_bootcmd for distro fallback in case of sdbootShengzhou Liu
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27arm: layerscape: Remove CONFIG_USB_MAX_CONTROLLER_COUNTRan Wang
Because COMFIG_DM_USB has been enabled and will not use it anymore. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27usb: host: Move CONFIG_XHCI_FSL to KconfigRan Wang
use Kconfig to select xhci accordingly. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27arm64: layerscape: Move CONFIG_HAS_FSL_XHCI_USB to KconfigRan Wang
Use Kconfig to select QE-HDLC and USB pin-mux. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-02Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1046aqds.h include/configs/ls1046ardb.h
2017-08-01arm: ls1021atwr: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm: ls1021atwr: Add distro boot supportAlison Wang
This patch includes common config_distro_defaults.h and config_distro_bootcmd.h for u-boot enviroments to support distro boot which automatically scan boot.scr from storage devices(e.g. SD/USB/SATA/SCSI disk) and execute autoboot script on LS1021ATWR board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-07-28configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that xHCD does not use CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
