path: root/include/configs/ls1021atwr.h
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: armv7: move CONFIG_ARMV7_PSCI to KconfigMasahiro Yamada
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms can select. Then, move CONFIG_ARMV7_PSCI, which is automatically enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-26ARMv7: PSCI: ls102xa: move secure text section into OCRAMHongbo Zhang
LS1021 offers two secure OCRAM blocks for trustzone. This patch moves all the secure text sections into the OCRAM. Signed-off-by: Wang Dongsheng <dongsheng.wang@nxp.com> Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26ARMv7: PSCI: ls102xa: add more PSCI v1.0 functions implementionHongbo Zhang
This patch implements PSCI functions for ls102xa SoC following PSCI v1.0, they are as the list: psci_version, psci_features, psci_cpu_suspend, psci_affinity_info, psci_system_reset, psci_system_off. Tested on LS1021aQDS, LS1021aTWR. Signed-off-by: Wang Dongsheng <dongsheng.wang@nxp.com> Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-26arm: ls1021atwr: Add SD secure boot targetSumit Garg
Add SD secure boot target for ls1021atwr. Implement board specific spl_board_init() to setup CAAM stream ID and corresponding stream ID in SMMU. Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. Reviewed-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-15ARM: PSCI: Add missing CONFIG_ARMV7_PSCI_NR_CPUS for PSCI enabled platformsChen-Yu Tsai
The original PSCI implementation assumed CONFIG_ARMV7_PSCI_NR_CPUS=4. Add this to platforms that have not defined it, using CONFIG_MAX_CPUS if it is defined, or the actual number of cores for the given platform. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-03include/configs: Numerous typo fixes: "controler" -> "controller".Robert P. J. Day
2016-03-21arm: ls102xa: Enable CONFIG_SYS_CONSOLE_IS_IN_ENV supportAlison Wang
CONFIG_SYS_CONSOLE_IS_IN_ENV needs to be enabled, so we could set stdout environment variable to specify the vga for the console output when LCD/HDMI is connected to the boards. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-01armv7: ls102xa: Increase the supported kernel sizeAlison Wang
Increase the kernel size supported for LS1021A platform. Define CONFIG_SYS_BOOTM_LEN to 64M. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: include/configs: move definition of CONFIG_CMD_BLOBAneesh Bansal
CONFIG_CMD_BLOB must be defined in case of Secure Boot. It was earlier defined in all config files. The definition has been moved to a common file which is included by all configs. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: include/configs: make secure boot header file uniformAneesh Bansal
The file fsl_secure_boot.h must be included in config file for Secure Boot. This is not required to be protected by any macro. CONFIG_FSL_CAAM must be defined and CONFIG_CMD_HASH should be turned on. The above was missing in some config files and all files have been made uniform in this respect. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-20serial: lpuart: Move CONFIG_FSL_LPUART to KconfigBin Meng
LPUART is seen on Freescale VF610 and QorIQ Layerscape devices. Create a Kconfig option and move it to defconfig for all boards that have this serial driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-20arm: ls1021atwr: Convert to driver model and enable serial supportBin Meng
Convert ls1021atwr_nor to driver model support. As a start, enable ns16550 serial port driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-30configs: ls1021atwr: Enable ID EEPROM for SD bootYao Yuan
I2C1 can work on ls102xa rev2.0 SD boot, so add ID EEPROM for SD boot. Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29arm: ls102xa: Set fdt_high and initrd_high to the value of 0xffffffffAlison Wang
As 3G/1G user/kernel memory split is used on LS1021A, the Linux kernel fails to access the device tree blob on boot. The reason is that u-boot relocates the device tree blob into high memory when booting the kernel and the kernel is unable to access the blob. To avoid this issue, fdt_high is set to the value of 0xffffffff. The device tree blob will not get relocated and is still in low memory to make it accessible to the kernel. For the same reason, initrd_high is set to the value of 0xffffffff too. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv7/ls1021a: move ns_access to common fileMingkai Hu
Config Security Level Register is different between different SoCs, so put the CSL register definition into the arch specific directory. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-26arm: ls1021a: Add QSPI or IFC support in SD bootAlison Wang
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in SD boot now. For the customer's demand, QSPI needs to be supported in SD boot too. This patch adds QSPI or IFC support in SD boot according to the corresponding defconfig. For detail, ls1021atwr_sdcard_ifc_defconfig is used to support IFC in SD boot and ls1021atwr_sdcard_qspi_defconfig is used to support QSPI in SD boot. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-26QE: modify the address of qe ucodeZhao Qiang
The address of uboot changed, so change qe ucode Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-26arm/fsl-ls: Add CONFIG_OF_STDOUT_VIA_ALIASScott Wood
This will allow OF-based earlycon to be used once the appropriate aliases are added to the device tree and kernel support is fixed. Signed-off-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-11configs: ls1021atwr: Enable DSPI for LS1021ATWRYao Yuan
DSPI2 can be verified when boot from QSPI now. Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-09-01arm/ls102xa:add hwconfig setting to support disable unused devicesZhuoyu Zhang
DEVDISRn registers provides a mechanism for gating clocks of IP blocks that are not used. Here we implement hwconfig option to allow users to disable unused peripherals on the board. For ex. If eSDHC/qDMA/eDMA are unused and with disabled status in dts, User can enable CONFIG_FSL_DEVICE_DISABLE and set "devdis:esdhc,qdma,edma" in hwconfig, thus ESDHC controller & eDMA/qDMA will be clock gated to save more power. Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03armv7/ls1021atwr: added deep sleep support in ubootTang Yuantian
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03armv7/lS1021atwr: Enable bootscript for secure bootgaurav rana
Enable bootscript support in secure boot for establishing chain of trust on LS1021atwr. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-08-03armv7/ls1021a: Reserve secure code into RAM instead of OCRAMZhuoyu Zhang
For ls1021a, Reserve secure code in to memory in case OCRAM is needed by other usage. Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-22ls1021atwr: Enable USB IP supportRamneek Mehresh
Enable USB IP support for both EHCI and XHCI for ls1021atwr platform Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-07-20arm/ls102xa: Add PSCI support for ls102xaWang Dongsheng
Base on PSCI services, implement CPU_ON/CPU_OFF for ls102xa platform. Tested on LS1021AQDS, LS1021ATWR. Test CPU hotplug times: 60K Test kernel boot times: 1.2K Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-06-30arm: ls102xa: Enable Driver Model SPI for ls1021atwrHaikun Wang
Enable Driver Model SPI for ls1021atwr board. DSPI and QSPI only be enabled when boot from QSPI. DSPI and QSPI are compatible under Driver Model SPI. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Tested-by: Review Code-CDREVIEW <CDREVIEW@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
