path: root/include/configs/ls1021aqds.h
2015-07-22ls1021aqds: Enable USB IP supportRamneek Mehresh
Enable USB IP support for both EHCI and XHCI for ls1021aqds platform Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-07-20arm/ls102xa: Add PSCI support for ls102xaWang Dongsheng
Base on PSCI services, implement CPU_ON/CPU_OFF for ls102xa platform. Tested on LS1021AQDS, LS1021ATWR. Test CPU hotplug times: 60K Test kernel boot times: 1.2K Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-01sf: dataflash: Rename to CONFIG_SPI_FLASH_DATAFLASHJagan Teki
Rename CONFIG_SF_DATAFLASH into CONFIG_SPI_FLASH_DATAFLASH as it follows the naming convention same as remaining configs. Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-30arm: ls102xa: Enable Driver Model SPI for ls1021aqdsHaikun Wang
Enable Driver Model SPI for ls1021aqds board. DSPI and QSPI is enabled only when boot from QSPI. DSPI and QSPI are compatible under Driver Model SPI. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-05-20arm: ls102xa: Adjust the load address of U-Boot for NOR bootAlison Wang
The original load address of U-Boot is 0x67f80000. The address space of NOR flash is 0x60000000 to 0x67ffffff. It will cause the size of u-boot couldn't be larger than 512K. As more features are supported in u-boot, the size of u-boot is larger than 512K. To fix this issue, the load address of U-Boot for NOR boot is adjusted to 0x60100000. In RCW, the PBI command needs to change as follows: .pbi -write 0xee0200, 0x67f80000 +write 0xee0200, 0x60100000 .end Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-04-21Add bootscript support to esbc_validate.gaurav rana
1. Default environment will be used for secure boot flow which can't be edited or saved. 2. Command for secure boot is predefined in the default environment which will run on autoboot (and autoboot is the only option allowed in case of secure boot) and it looks like this: #define CONFIG_SECBOOT \ "setenv bs_hdraddr 0xe8e00000;" \ "esbc_validate $bs_hdraddr;" \ "source $img_addr;" \ "esbc_halt;" #endif 3. Boot Script can contain esbc_validate commands and bootm command. Uboot source command used in default secure boot command will run the bootscript. 4. Command esbc_halt added to ensure either bootm executes after validation of images or core should just spin. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-02-24arm/ls1021a: add PCIe settingsMinghuan Lian
The patch enables and adds PCIe settings for boards LS1021AQDS and LS1021ATWR. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-24fsl/ls1021qds: Add deep sleep supporttang yuantian
Add deep sleep support on Freescale LS1021QDS platform. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> [York Sun: Fix conflict in fdt.c] Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23arm: ls102xa: Add LPUART support for LS1021AQDS boardAlison Wang
This patch adds LPUART support for LS1021AQDS board. For ls1021aqds_nor_lpuart_defconfig, LPUART is used as the console. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23ls102xa: dcu: Add platform support for DCU on LS1021AQDS boardXiubo Li
This patch adds the CH7301 HDMI options and the common configuration for DCU on LS1021AQDS board. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Cc: Jason Jin <Jason.Jin@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: Setting device's stream id for SMMUs.Xiubo Li
LS1 has 4 SMMUs for address translation of the masters. All the SMMUs' stream IDs are 8-bit. The address translation depends on the stream ID of the incoming transaction. Each master has unique stream ID assigned to it and is configurable through SCFG registers. The stream ID for the masters is identical and share the same register field of STREAM ID registers. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: allow all the peripheral access permission as R/W.Xiubo Li
The Central Security Unit (CSU) allows secure world software to change the default access control policies of peripherals/bus slaves, determining which bus masters may access them. This allows peripherals to be separated into distinct security domains. Combined with SMMU configuration of the system masters privileges, these features provide protection against indirect unauthorized access to data. For now we configure all the peripheral access permissions as R/W. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ls102xa: changing a few targets' configurations.Xiubo Li
Enable hypervisors utilizing the ARMv7 virtualization extension on the LS1021A-QDS/TWR boards with the A7 core tile, we add the required configuration variable. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add NAND boot support for LS1021AQDS boardAlison Wang
This patch adds NAND boot support for LS1021AQDS board. SPL framework is used. PBL initialize the internal RAM and copy SPL to it, then SPL initialize DDR using SPD and copy u-boot from NAND flash to DDR, finally SPL transfer control to u-boot. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add QSPI boot support for LS1021AQDS/TWR boardAlison Wang
This patch adds QSPI boot support for LS1021AQDS/TWR board. The QSPI boot image need to be programmed into the QSPI flash first. Then the booting will start from QSPI memory space. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Fix SD/NAND/QSPI boot defination error for QE supportAlison Wang
The SD/NAND/QSPI boot definations are wrong for QE support, this patch is to fix this error. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls1021a: Add CONFIG_DOS_PARTITION and CONFIG_CMD_FAT supportAlison Wang
This patch will fix the bug that the partitions on the SD card could not be accessed and add the support for the FAT fs. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Add SD boot support for LS1021AQDS boardAlison Wang
This patch adds SD boot support for LS1021AQDS board. SPL framework is used. PBL initialize the internal RAM and copy SPL to it, then SPL initialize DDR using SPD and copy u-boot from SD card to DDR, finally SPL transfer control to u-boot. Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11arm: ls102xa: Update PCIe dts node statusMinghuan Lian
The patch changes PCIe dts node status to 'disabled' if the corresponding controller is disabled according to serdes protocol. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-11-24ls102xa: ifc: nor: fix the write issue when bytes unalignedYuan Yao
Add define CONFIG_SYS_WRITE_SWAPPED_DATA. For LS1021AQDS and LS1021QTWR nor flash write should swap the bytes when handle unaligned tail bytes. Because of the ending, if the date bus width is 16-bits and the number of bytes is odd, we should swap the byte when write the last one. Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-24ls1: config: Enable USB EHCI Host on LS1021AQDSNikhil Badola
Enable USB EHCI Host on LS1021AQDS Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-23config: remove redundant CONFIG_SYS_PROMPT definesMasahiro Yamada
Since commit 0defddc851ed (config: Add a default CONFIG_SYS_PROMPT), each board header does not need to define CONFIG_SYS_PROMPT as long as it uses the default prompt "=> ". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-19qe: add qe support to ls1021aqdsZhao Qiang
add qe support to ls1021aqds Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-23kconfig: move CONFIG_SYS_HZ to lib/KconfigMasahiro Yamada
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h (but some boards still have redundant definitions). This commit moves the definition and the document in README to Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000, the sanity check in lib/time.c should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-10-16ls102x: Add support for secure boot and enable blob commandRuchika Gupta
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16ls102x: configs - Add hash command in freescale LS1 platformsRuchika Gupta
Hardware accelerated support for SHA-1 and SHA-256 has been added. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-25board/ls1021aqds: Add DDR4 supportYork Sun
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig for this variant to enable DDR4 support. RAW timing parameters are not added for DDR4. The board timing parameters are only tuned for single- rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM availability. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com>
2014-09-08arm: ls102xa: Add basic support for LS1021AQDS boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021AQDS board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
