path: root/include/configs/ls1021aqds.h
2017-04-17armv7: ls1021a: Drop macro CONFIG_LS102XAYork Sun
Use CONFIG_ARCH_LS1021A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2017-04-14Convert CONFIG_FSL_DCU_FB to KconfigSanchayan Maity
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB and convert it to Kconfig. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05fsl: ls102x: remove redundant GENERIC_TIMER_CLKAndre Przywara
Some Freescale boards used an extra version of the constant to hold the Generic Timer frequency. This can easily be covered by the now unified COUNTER_FREQUENCY constant, so remove this extra variable from those boards. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05ARM: rename CONFIG_TIMER_CLK_FREQ to COUNTER_FREQUENCYAndre Przywara
Many ARMv8 boards define a constant COUNTER_FREQUENCY to specify the frequency of the ARM Generic Timer (aka. arch timer). ARMv7 boards traditionally used CONFIG_TIMER_CLK_FREQ for the same purpose. It seems useful to unify them. Since there are less occurences of the latter version, lets convert all users over to COUNTER_FREQUENCY. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-18arm: layerscape: Enable UUID & GPT partition for NXP's ARM SoCPrabhakar Kushwaha
Enable UUID and GPT partition support for NXP's ARM based SoCs i.e. LS1012A, LS1021A, LS1043A, LS1046A and LS2080A. Also enable DOS partition for LS1012AFRDM boards. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18kconfig: move FSL_PCIE_COMPAT to platform KconfigHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18arm: ls1021a: Enable PCIe in defconfigsMinghuan Lian
The patch enables PCIe in ls1021a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1021aqds.h include/configs/ls1021atwr.h
2016-10-06armv7: ls1021a: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and related config options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06arm: Move SYS_FSL_SRDS_* and SYS_HAS_SERDES to KconfigYork Sun
Move these options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06ARMv7: LS102xA: Move two macros from header files to KconfigHongbo Zhang
Following commits 217f92b and 1544698, these two config CPU_V7_HAS_NONSEC and CPU_V7_HAS_VIRT are moved to Kconfig, for correctly select ARMV7_PSCI. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> [York Sun: Reformatted commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06armv7: LS1021a: enable i-cache in start.SXiaoliang Yang
Delete CONFIG_SKIP_LOWLEVEL_INIT define in ls1021atwr.h and ls1021aqds.h can let it run cpu_init_cp15 to enable i-cache. First stage of u-boot can run faster after that. There is a description about skip lowlevel init in board/freescale/ls1021atwr/README. Signed-off-by: Xiaoliang Yang <xiaoliang.yang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
trini: Drop local memset() from examples/standalone/mem_to_mem_idma2intr.c Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26armv7: ls1021a: Convert CONFIG_LS1_DEEP_SLEEP to Kconfig optionYork Sun
Move this option to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> CC: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
2016-09-14nxp: ls102xa: add LS1 PSCI system suspendHongbo Zhang
The deep sleep function of LS1 platform, is mapped into PSCI system suspend function, this patch adds implementation of it. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14nxp: ls102xa: add registers definition for system sleepHongbo Zhang
This patch adds definitions of all the regesters necessary for system sleep. Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
