path: root/include/configs/ls1012a_common.h
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-03board: Enable DHCP distro boot for LS1012a, LS1021aYunfeng Ding
Enable DHCP distro boot for Layerscape LS1012A and LS1021A. Signed-off-by: Yunfeng Ding <yunfeng.ding@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19armv8: layerscape: move CONFIG_LAYERSCAPE to KconfigRajesh Bhagat
Moves CONFIG_LAYERSCAPE for all NXP Layerscape platforms. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-12-06armv8: ls1012ardb: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1012ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - define BOOTCOMMAND for TFABOOT - enable PFE validation for secure boot Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-29drivers: i2c: mxc: Update SYS_I2C_MXC_I2C support in KconfigSriram Dash
NXP layerscape platforms like ls1088a, ls2088a uses MXC I2C Controller. -Remove dependency of MX6 for the same. Update related configs to use Kconfig file. -Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig -Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig -Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2018-03-22configs: ls1012a: add pfe configuration for LS1012ACalvin Johnson
Add configurations for PFE. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Anjaneyulu Jagarlmudi <anji.jagarlmudi@nxp.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-17arm64: ls1012a: Add sata distro boot supportYuantian Tang
Sata is equipped on ls1012a and can be a boot source. Add sata boot support as an option if available. Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-13arm64: ls1012ardb: Add distro boot supportRajesh Bhagat
Include common config_distro_defaults.h and config_distro_bootcmd.h for u-boot enviroments to support automatical distro boot which scan boot.scr from external storage devices(e.g. SD and USB) and execute autoboot script. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-06armv8: ls1012a: Modify Kernel and Environment offsetBhaskar Upadhaya
Kernel is now located at 0x1000000 instead of 0xa00000 and envirorment variables are located at 3MB offset instead of 2MB in Flash. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: configs: ls1012a: correct the generic timer frequencyYuantian Tang
On ls1012a soc, core clock source frequency is fixed at 100Mhz. Generic timer frequency is core clock source divided by 4, which is 25Mhz. Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-10configs: Re-sync CONFIG_CMD_IMLS with moveconfigTuomas Tynkkynen
The option is specified in Kconfig, but still a few config header files are overriding the choice by #undef'ing it. Re-sync the option with moveconfig to rid of the #undefs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-05common: arm: freescale: layerscape: Move header files out of common.hSimon Glass
We should not have an arch-specific header file in common.h. Adjust the board files a little so it is not needed, and drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-05-23armv8: ls1012a: fix the size of flash for multiple boardsSuresh Gupta
LS1012AFRDM, LS1012ARDB, LS1012AQDS all have S25FS512S flash of 64MB size. Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com>
2017-05-23armv8: layperscape: remove CONFIG_SPI_FLASH_BAR from some platformsSuresh Gupta
ls1012ardb, ls1046ardb, ls2080ardb have S25FS512S flash which does not support Bank Address Register commands. Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-17armv8: LS1012ARDB: Add QSPI Secure Boot targetVinitha Pillai-B57223
Add QSPI Secure Boot target to enable chain of trust Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-28armv8: fsl-lsch2: Use Chassis-2 streamid definition for ls1012aBharat Bhushan
LS1012A is Chassis-2 type SOC and shares same streamid definition. This patch adds using streamids for ls1012a Signed-off-by: Bharat Bhushan <Bharat.Bhushan@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03board: freescale: ls1012a: Enable secure DDR on LS1012A platformsPrabhakar Kushwaha
PPA binary needs to be relocated on secure DDR, hence marking out a portion of DDR as secure if CONFIG_SYS_MEM_RESERVE_SECURE flag is set Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-25Convert CONFIG_ARCH_EARLY_INIT_R to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_EARLY_INIT_R Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-18armv8/fsl-lsch2: refactor the clock system initializationHou Zhiqiang
Up to now, there are 3 kind of SoCs under Layerscape Chassis 2, like LS1043A, LS1046A and LS1012A. But the clocks tree has a lot of differences, for instance, the IP modules have different dividers to derive its clock from Platform PLL. And the core cluster PLL and platform PLL maybe have different reference clocks, such as LS1012A. Another problem is which clock/PLL should be described by sys_info->freq_systembus, it is confused in Layerscape Chissis 2. This patch is to bind the sys_info->freq_systembus to the Platform PLL, and handle the different divider of IP modules separately between different SoCs, and separate reference clocks of core cluster PLL and platform PLL. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-21armv8:ls1012a: Update bootargs for fast-bootPratiyush Srivastava
Add optimization parameters like "quiet" in bootargs to reduce the system boot time Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Harninder Rai <harninder.rai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1021aqds.h include/configs/ls1021atwr.h
2016-10-07armv8: ls1012a: Updating CONFIG_EXTRA_ENV_SETTINGSPratiyush Srivastava
Remove ramdisk_addr, ramdisk_size and update UART baud-rate. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-06arm: Move SYS_FSL_SRDS_* and SYS_HAS_SERDES to KconfigYork Sun
Move these options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06arm: Move FSL_LSCH2 FSL_LSCH3 to KconfigYork Sun
Move these options to Kconfig and create a sub-menu to avoid name conflict with other architectures. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-26armv8: ls1012a: Convert CONFIG_LS1012A to Kconfig option ARCH_LS1021AYork Sun
Move this config to Kconfig option and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> CC: Calvin Johnson <calvin.johnson@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-03armv8: ls1012a: Add support of ls1012aqds boardPrabhakar Kushwaha
QorIQ LS1012A Development System (LS1012AQDS) is a high-performance development platform, with a complete debugging environment. The LS1012AQDS board supports the QorIQ LS1012A processor and is optimized to support the high-bandwidth DDR3L memory and a full complement of high-speed SerDes ports. Signed-off-by: Calvin Johnson <calvin.johnson@nxp.com> Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
