path: root/include/configs/lpd7a400.h
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various l* named board config files.Jon Loeliger
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-06-10* Patch by Paul Ruhland, 10 Jun 2004:wdenk
fix support for Logic SDK-LH7A404 board and clean up the LH7A404 register macros. * Patch by Matthew McClintock, 10 Jun 2004: Modify code to select correct serial clock on Sandpoint8245
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
