path: root/include/configs/lpc2292sodimm.h
2009-03-29lpc2292: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_LPC2292_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various l* named board config files.Jon Loeliger
2007-07-04Fix a few file permission problems.Wolfgang Denk
2007-06-06Coding Style cleanup; generate new CHANGELOG file.Wolfgang Denk
2007-05-18Reduce line lengths to 80 characters max.Peter Pearse
2007-05-09New board SMN42 branchPeter Pearse
2007-01-24Add port for the lpc2292sodimm evaluation board from EmbeddedArtistsGary Jennejohn
