path: root/include/configs/legoev3.h
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-23Convert CONFIG_MX_CYCLIC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MX_CYCLIC Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: David Lechner <david@lechnology.com>
2019-07-13ARM: legoev3: convert to driver modelDavid Lechner
This converts LEGO MINDSTORMS EV3 to the driver model. MMC, SERIAL, SPI and SPI_FLASH are converted. The device tree contains only the minimal nodes required by U-Boot since the size of U-Boot is limited to 256K on this device. Signed-off-by: David Lechner <david@lechnology.com>
2019-06-05configs/legoev3: define CONFIG_SKIP_LOWLEVEL_INITDavid Lechner
This adds a define for CONFIG_SKIP_LOWLEVEL_INIT in the legoev3 config. On the EV3, U-Boot is loaded into RAM by another bootloader, so we don't need the lowlevel init in U-Boot. Signed-off-by: David Lechner <david@lechnology.com> Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-05ARM: legoev3: update boot script to load uEnv.txt and .dtbDavid Lechner
This updates the LEGO MINDSTORMS EV3 boot script to try loading a uEnv.txt file and a da850-lego-ev3.dtb device tree during boot. Signed-off-by: David Lechner <david@lechnology.com>
2018-06-05ARM: legoev3: remove unused configuration optionsDavid Lechner
This removes the unused clock and RAM config options that were cargo- culted when this board was copied from the DA850 EVM. Signed-off-by: David Lechner <david@lechnology.com>
2018-06-05ARM: legoev3: disable networkingDavid Lechner
This disables networking related items in the config. The EV3 does not have any networking hardware, so this is wasted space. Signed-off-by: David Lechner <david@lechnology.com>
2018-06-05ARM: legoev3: increase flash image sizesDavid Lechner
This increases the kernel image to 4M and the rootfs image to 10M. It is getting hard to get a kernel image to fit in 3M. Signed-off-by: David Lechner <david@lechnology.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-30Convert CONFIG_SYS_DV_CLKMODE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_DV_CLKMODE CONFIG_SYS_DA850_PLL0_POSTDIV CONFIG_SYS_DA850_PLL0_PLLDIV1 CONFIG_SYS_DA850_PLL0_PLLDIV2 CONFIG_SYS_DA850_PLL0_PLLDIV3 CONFIG_SYS_DA850_PLL0_PLLDIV4 CONFIG_SYS_DA850_PLL0_PLLDIV5 CONFIG_SYS_DA850_PLL0_PLLDIV6 CONFIG_SYS_DA850_PLL0_PLLDIV7 CONFIG_SYS_DA850_PLL1_POSTDIV CONFIG_SYS_DA850_PLL1_PLLDIV1 CONFIG_SYS_DA850_PLL1_PLLDIV2 CONFIG_SYS_DA850_PLL1_PLLDIV3 Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-22Convert CONFIG_SOC_DA8XX et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SOC_DA8XX CONFIG_SOC_DA850 CONFIG_DA850_LOWLEVEL CONFIG_MACH_DAVINCI_DA850_EVM CONFIG_SYS_DA850_PLL_INIT CONFIG_SYS_DA850_DDR_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: David Lechner <david@lechnology.com> [trini: Rework CONFIG_SYS_DA850_PLL_INIT so it's selected on SOC_DA8XX] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SAVES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SAVES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-05common: arm: davinci: Move header file out of commonSimon Glass
We should not have an arch-specific header file in common.h. Instead, use the asm/hardware.h header to provide the required declarations, and drop the common.h changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-11ARM: davinci: remove unused CONFIG_DAVINCI_MMC_SD1Masahiro Yamada
This CONFIG is not referenced from anywhere. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-03ARM: davinci: Move CONFIG_SYS_DA850_DDR_INIT to KconfigFabien Parent
Clean config headers by moving CONFIG_SYS_DA850_DDR_INIT away to a Kconfig file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-03ARM: davinci: Move CONFIG_SYS_DA850_PLL_INIT to KconfigFabien Parent
Clean config headers by moving CONFIG_SYS_DA850_PLL_INIT away to a Kconfig file. Signed-off-by: Fabien Parent <fparent@baylibre.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-18Remove references to CONFIG_CMD_EXT3, no such commandRobert P. J. Day
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14arm: Add support for LEGO MINDSTORMS EV3David Lechner
This is based on the davinci da850evm. It can boot from either the on-board 16MB flash or from a microSD card. It also reads board information from an I2C EEPROM. The EV3 itself initally boots from write-protected EEPROM, so no u-boot SPL is needed. Signed-off-by: David Lechner <david@lechnology.com> Reviewed-by: Tom Rini <trini@konsulko.com>
