path: root/include/configs/lacie_kw.h
2014-03-12kirkwood: kwbimage: refactor CONFIG_SYS_KWD_CONFIGMasahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_KWD_CONFIG and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michael Walle <michael@walle.cc> Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Dave Purdy <david.c.purdy@gmail.com> Cc: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net> Cc: Luka Perkov <luka@openwrt.org> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Siddarth Gore <gores@marvell.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Eric Cooper <ecc@cmu.edu> Cc: Suriyan Ramasami <suriyan.r@gmail.com>
2013-06-20net2big_v2: initialize I2C fan at startupSimon Guinot
This patch ensures minimal cooling for the net2big_v2 by automatically starting the I2C fan (GMT G762) at low speed (2800 RPM). Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2012-10-03ARM: add support for d2 Network v2Simon Guinot
This patch adds support for the LaCie board d2 Network v2 which share a lot of hardware caracteristics with the 2Big Network v2. - CPU: Marvell 88F6281 1200Mhz - SDRAM memory: 256MB DDR2 400Mhz - 2 SATA ports: internal and eSATA - Gigabit ethernet: PHY Marvell 88E1116R - Flash memory: SPI NOR 512KB (Macronix MX25L4005A) - i2c EEPROM: 512 bytes (24C04 type) - 2 USB2 ports: host and host/device - 1 push button - 1 power switch - 1 SATA LED (bi-color, blue and red) Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-10-03ARM: add support for Network Space v2 Lite and MiniSimon Guinot
This patch adds support for the LaCie boards Network Space v2 (Lite and Mini). This two boards are derived from the Network Space v2 and a lot of hardware caracteristics are shared. - CPU: Marvell 88F6192 800Mhz - SDRAM memory: 128MB DDR2 200Mhz - 1 SATA port: internal - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: SPI NOR 512KB (Macronix MX25L4005A) - i2c EEPROM: 512 bytes (24C04 type) - 2 USB2 ports (Lite only): host and host/device - 1 push button - 1 SATA LED (bi-color, blue and red) Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-10-03lacie_kw: add support for EFI partitionsSimon Guinot
Defines CONFIG_EFI_PARTITION for LaCie boards. Additionally this patch defines CONFIG_DOS_PARTITION. Note that this definition is implicit in mv_common.h when CONFIG_CMD_USB is enabled. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-07-07lacie_kw: fix CONFIG_SYS_KWD_CONFIG for inetspace_v2Simon Guinot
2012-07-07lacie_kw: fix SDRAM banks number for net2big_v2Simon Guinot
2011-12-06ARM: remove duplicated code for LaCie boardsSimon Guinot
This patch groups together all the common functions for LaCie boards: Ethernet PHY and MAC address initializations. Moreover the configurations for LaCie Kirkwood boards are merged into a single file: include/configs/lacie_kw.h Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
