path: root/include/configs/kzm9g.h
2012-10-16i2c: sh_i2c.c: support I2C2, I2C3 and I2C4Tetsuyuki Kobayashi
sh_i2c.c support I2C0 and I2C1. This patch extends it to I2C4. Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-16i2c: sh_i2c.c: adjust for SH73A0Tetsuyuki Kobayashi
Adjust i2c_raw_read() in sh_i2c.c to work for SH73A0. After this patch, "i2c md" and "i2c mw" command on U-Boot work properly on KZM-A9-GT board. Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-16i2c: sh_i2c.c: support iccl and icch extensionTetsuyuki Kobayashi
R-mobile SoC (at least SH73A0) has extension bits to store 8th bit of iccl and icch. This patch add support for the extentin bits. Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-10-03arm: rmobile: kzm9g: Add CONFIG_GLOBAL_TIMER to board config fileNobuhiro Iwamatsu
kzm9g board use global timer. But by commit 813ffda31, timer function of rmobile was changed that global timer might be used, when CONFIG_GLOBAL_TIMER was defined. This add CONFIG_GLOBAL_TIMER to board config file. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: remove unrelated configNobuhiro Iwamatsu
Remove CONFIG_ARM_CORTEXA9. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Add LIBFDT supportNobuhiro Iwamatsu
2012-10-03arm: rmobile: kzm9g: remove unrelated configTetsuyuki Kobayashi
Remove CONFIG_INTEGRATOR and CONFIG_ARCH_CINTEGRATOR. These are not for kzm9g. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: add NFS_TIMEOUT in config fileTetsuyuki Kobayashi
Set NFS_TIMEOUT to 10,000 msec. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Fix CONFIG_BAUDRATE settingTetsuyuki Kobayashi
The value of CONFIG_BAUDRATE is treated as string and put as initial value of environment variable. If it begin with '(', it is wrongly parsed to 0 in number. So I removed '(' and ')'. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: change prompt to board specificTetsuyuki Kobayashi
Change U-Boot prompt to board specific one. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Modify sdram areaTetsuyuki Kobayashi
Reserve first 16MB for RT-CPU (as same as kernel config). Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: Add supoprt for KMC KZM-A9-GT boardNobuhiro Iwamatsu
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 512MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SMSC) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
