path: root/include/configs/kylin_rk3036.h
2016-10-01rockchip: add boot-mode support for rk3288, rk3036Jacob Chen
rockchip platform have a protocol to pass the the kernel reboot mode to bootloader by some special registers when system reboot. In bootloader we should read it and take action. We can only setup boot_mode in board_late_init becasue "setenv" need env setuped. So add CONFIG_BOARD_LATE_INIT to common header and use a entry "rk_board_late_init" to replace "board_late_init" in board file. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: move partitons define from 3036-kylin to 3036-commonJacob Chen
To keep it same with 3288. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: remove the duplicated macro configjk.kernel@gmail.com
CONFIG_DOS_PARTITION and CONFIG_EFI_PARTITION are already included in config_distro_defaults.h, and we don't need them in SPL stage. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: kylin: Store env in emmcJeffy Chen
There's a 64K reserved area at the end of the first 4M. Store env there, so we can use fastboot to flash it. Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: kylin: Check fastboot requestJeffy Chen
We will save boot mode flag in grf's os_reg[4], if fastboot requested or fastboot key pressed, try to enter fastboot mode at preboot stage. Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: kylin: Add default gpt partition tableJeffy Chen
Add default android gpt partition table for kylin board. Use "gpt write mmc 0 $partitions" to apply. Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-13rockchip: Add basic support for kylin boardhuang lin
kylin board use rk3036 SOC, 512M sdram, 8G emmc. This add some basic files required to allow the board to output serial message and can run command(mmc info etc). Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
