path: root/include/configs/kp_imx6q_tpc.h
2019-04-13configs: move CONFIG_MXC_OCOTP to KconfigMarcel Ziswiler
While commit 3e020f03e94f ("driver: misc: add MXC_OCOTP Kconfig entry") introduced a Kconfig entry it did not actually migrate all configurations to using it. As CONFIG_MXC_OCOTP was in mx{6/7}_common.h enable it by default on those architectures. Additionally, also enable it on ARCH_IMX8M and ARCH_VF610 where all current members enabled it through their legacy configuration header files. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-05-17mx6: remove duplicated BOUNCE_BUFFER definesPeter Robinson
The mx6_common.h file already defines BOUNCE_BUFFER so no need to definit it again in specific configs. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2018-04-15imx: board: Add support for the K+P's kp_imx6q_tpc boardLukasz Majewski
This commit provides support for Kieback & Peter GmbH IMX6Q based TPC board. U-boot console output: U-Boot SPL 2018.05-rc1-00005-g631e2d01fd (Apr 04 2018 - 21:16:24 +0200) Trying to boot from MMC1 U-Boot 2018.05-rc1-00005-g631e2d01fd (Apr 04 2018 - 21:16:24 +0200) CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 37C Reset cause: POR Board: K+P KP_IMX6Q_TPC i.MX6Q Watchdog enabled I2C: ready DRAM: 2 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... OK In: serial Out: serial Err: serial Net: FEC [PRIME] Autoboot in 3 seconds
