path: root/include/configs/koelsch.h
2018-02-13spi: Migrate CONFIG_SH_QSPI to KconfigTuomas Tynkkynen
2018-01-24ARM: rmobile: Convert CONFIG_R8A77xx to KconfigMarek Vasut
Convert these configuration options to Kconfig, update board defconfigs and drop them from whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-02-25arm: rmobile: koelsch: Add support SDHINobuhiro Iwamatsu
Koelsch board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Koelsch board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Stop clock prior to booting kernelNobuhiro Iwamatsu
This stops clock except INTC-RT, MSIF, INTC-SYS, IRQC and SCIF before kernel boots. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: replacement of common parts of config by rcar-gen2-common.hNobuhiro Iwamatsu
Common part of config for lager, koelsch, alt and gose board will be able to replace rcar-gen2-common.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: Move sh-i2c of the address defined to common headerNobuhiro Iwamatsu
R-Car SoCs of rmobile have same IP of sh-i2c, and have same address. This moves sh-i2c of the address defined to rcar-base.h as common header of R-Car SoCs, and headers of each SoCs. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: koelsch: Remove board_late_init functionNobuhiro Iwamatsu
Koelsch board does not use board_late_init function. This removes this function and define of BOARD_LATE_INIT from config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: koelsch: Add external RAM bootNobuhiro Iwamatsu
If CONFIG_RMOBILE_EXTRAM_BOOT is enabled, U-Boot is booted from External RAM. The default boot address is 0x70000000. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-10-09arm: rmobile: koelsch: Add CONFIG_SCIF_USE_EXT_CLKNobuhiro Iwamatsu
SCIF of koelsch use external clock mode. This enables external clock mode on koelsch board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-09usb: ehci: rmobile: Remove xHCI addressNobuhiro Iwamatsu
echi-rmobile does not support xHCI. This removes xHCI address from address table. And this revise a value of CONFIG_USB_MAX_CONTROLLER_COUNT for lager board and koelsh board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: koelsch: Enable CONFIG_SYS_GENERIC_BOARDNobuhiro Iwamatsu
Add CONFIG_SYS_GENERIC_BOARD to use common/board_*.c for koelsch. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: koelsch: Add support ext4/fat write commandNobuhiro Iwamatsu
2014-05-21arm: rmobile: koelsch: Add support command and filesystems of VFATNobuhiro Iwamatsu
2014-05-21arm: rmobile: koelsch: Add support USB controllerNobuhiro Iwamatsu
Koelsch board has USB ports. This add support of USB controller of rmobile. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: koelsch: Enable optimization of thumbNobuhiro Iwamatsu
This adds CONFIG_SYS_THUMB_BUILD to config, in order to enable optimization of thumb. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: koelsch: Remove CONFIG_USE_ARCH_MEMSET and MEMCPYNobuhiro Iwamatsu
Because do not need these feature to koelsch board, this delete it. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: koelsch: Remove define of SCIF registerNobuhiro Iwamatsu
The define of SCIF register was already defined in rcar-base.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-04-28arm: rmobile: koelsch: Update calculation of CONFIG_SH_TMU_CLK_FREQNobuhiro Iwamatsu
CONFIG_SH_TMU_CLK_FREQ of koelsch is calculated from the external clock. This defines RMOBILE_XTAL_CLK, this updates the calculation of CONFIG_SH_TMU_CLK_FREQ. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-04-28arm: rmobile: koelsch: Remove NOR-Flash supportNobuhiro Iwamatsu
Koelsch board has NOR-Flash. But user uses SPI-Flash ROM instead of NOR-Flash. This removed the setting of NOR-Flash. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19config: remove platform CONFIG_SYS_HZ definition part 3Masahiro Yamada
This commit removes platform CONFIG_SYS_HZ definition for the remainders of part1 (commit cdb23792) and part2 (commit f232950f). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <rob.herring@calxeda.com>
2014-01-16arm: koelsch: Add support QSPI device and enable boot from SPI flashNobuhiro Iwamatsu
This supports SH-QSPI device on koelsch board, and enable booting from SPI flash. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-18arm: koelsch: Add support reset functionNobuhiro Iwamatsu
2013-12-18arm: koelsch: Add support I2CNobuhiro Iwamatsu
This supports sh_i2c on koelsch board. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-12-18arm: koelsch: Add support EthernetNobuhiro Iwamatsu
The koelsch board has one sh-ether device. This supports sh-ether. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-12-03arm: rmobile: Add support koelsch boardNobuhiro Iwamatsu
The koelsch board has R8A7791, 2GB DDR3-SDRAM, USB, Quad SPI, Ethernet, and more. This patch supports the following functions: - DDR3-SDRAM - SCIF Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
