path: root/include/configs/km
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-07powerpc: mpc85xx: kmp204x: Fix compiling error for usb errataYork Sun
Commit 9262367 moves USB errata workaround into a C file. This causes compiling error for kmcoge4 and kmlion1. To enable the errata workaround, define CONFIG_USB_EHCI_FSL in common header. Signed-off-by: York Sun <york.sun@nxp.com> Cc: Marek Vasut <marex@denx.de> Cc: Ed Swarthout <Ed.Swarthout@nxp.com> Cc: Sriram Dash <sriram.dash@nxp.com> Fixes: 92623672f9d3 ("fsl: usb: make errata function common for PPC and ARM")
2016-05-03include/configs: Numerous typo fixes: "controler" -> "controller".Robert P. J. Day
2016-03-14Merge git://git.denx.de/u-boot-dmTom Rini
2016-03-14Drop CONFIG_CRAMFS_CMDLINESimon Glass
This option doesn't do anything. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18km8309: change the default QE_FW addressValentin Longchamp
It should be after the u-boot reserved sectors and before the env sectors, since the solution used for kmvect1 (tell the linker to put the firmware into the u-boot produced binary, at the end of the area) should be the exception. The #define is only "conditional" so that we can still support kmvect1. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km83xx: use CONFIG_ENV_ADDR for the newenv env commandValentin Longchamp
The hardcoded value are bad, since the address could change between different boards. Furthermore, the relevant #defines are set only if #undefined here, so that they can be changed by some boards if required. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/km8309: define CONFIG_SYS_DDRCDRValentin Longchamp
For consistency with all the other km83xx plaforms, this should also be defined for km8309. The same settings as for km8321 are taken. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/km8321: define CONFIG_SYS_DDRCDRValentin Longchamp
On the km8321 boards is CONFIG_SYS_DDRCDR not defined, which leads to the DDRCDR not being configured at startup and still containing the reset value. The required settings for our km8321 hardware designs are different than the reset value and must be set with CONFIG_SYS_DDRCDR, that is used by mpc83xx's cpu_init_f function at early CPU initialization. The important settings are the DDR2 internal voltage level and the half-strength "drivers". In our case where the DRAM chips are soldered on board and the routing for these signals under control, half-strength is sufficient as a few measurements done in the lasts have shown. Since all the hardware qualification tests have been performed with half strength, the nominal strength settings are removed in favor of the default reset half strength settings. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/powerpc: move open firmware defines to km-powerpc.hHolger Brunck
We use the same settings for open firmware defines on all our powerpc targets, so move them from the CPU specific headers to the common powerpc header. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/powerpc: increase space for kernel imange and FDT blobHolger Brunck
128kByte and 3,986MB may be in the future too little for kernel the fdt blob respectively the kernel image. So increase the reserved areas here, we have the space for this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km: update the boot script to check for a DTBValentin Longchamp
If a DTB is found with cramfsls, the bootscript continues as expected. If none is found, the cramfsloadfdt and boot subbootcmds are updated to not load the DTB from cramfs and not pass it to the kernel. The kernel thus must have an appended DTB otherwise the boot will fail. This is required for the km_kirkwood boards that must support .esw where the DTB sometimes is appended (for backwards compatibility) and sometimes is passed correctly (as we do now for all newer boards). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18km/common: stop u-boot only if someone press <SPACE>Holger Brunck
To prevent u-boot to stop accidently e.g. due to line noise on the serial line, we now use the option CONFIG_AUTOBOOT_KEYED. We choose the <SPACE> key for this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18arm/km_kirkwood: remove KM_ENV_BUS and use CONFIG_I2C_ENV_EEPROM_BUSValentin Longchamp
KM_ENV_BUS was used for nothing else than an direct assignment to CONFIG_I2C_ENV_EEPROM_BUS. To avoid this, directly use CONFIG_I2C_ENV_EEPROM_BUS instead. Patchwork: http://patchwork.ozlabs.org/patch/399411/ Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-17mpc83xx: preempt premature board support removal by setting GENERIC_BOARDKim Phillips
Boards that haven't been converted to GENERIC_BOARD does *not* mean they should be removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2015-02-21ARM: kirkwood: move SoC headers to mach-kirkwood/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-kirkwood/* -> arch/arm/mach-kirkwood/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2014-12-15mpc85xx: inhibit qman and bman portals by defaultJeffrey Ladouceur
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is required when supporting power management. Signed-off-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14keymile/powerpc: move to the architecture-generic board systemValentin Longchamp
This converts all the Keymile powerpc boards to the generic board initialization. This includes the 3 Keymile powerpc subsystems: km82xx, km83xx, and kmp204x. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-14mpc85xx/kmp204x: raise u-boot size to 768KBValentin Longchamp
Until now this defined to be 512KB and the total binary size actually was on the edge of this limit. Most of the powerpc boards have thus moved to 768KB. Since on the current kmp204x boards there is 1MB reserved for u-boot on the SPI boot flash, there is no problem to set the limit to 768KB as well to be on line with the other powerpc boards and to eventually configure in some additional features (and binary size) to u-boot. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-12km_arm: convert the km_arm boards to the generic board supportValentin Longchamp
This implies that all the km_kirkwood boards and their variants now are using the generic board init sequence. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-08-20km-powerpc: define CONFIG_PRAM to protect PHRAM and PNVRAMValentin Longchamp
When u-boot initializes the RAM (early in boot) it looks for the "pram" env variable to know which is area it cannot use. If the "pram" env variable is not found, the default CONFIG_PRAM value is used. This value used to be 0 (no protection at all). This patch sets it to a value that covers PHRAM and PNVRAM that must be protected in our case. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-01kmp204x: CPU watchdog enabledBoschung, Rainer
The booting of the board is now protected by the CPU watchdog. A failure during the boot phase will end up in board reset. Signed-off-by: Rainer Boschung <rainer.boschung@keymile.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-13kmp204x: enable the errata commandValentin Longchamp
2014-05-13kmp204x: update the CONFIG_PRAM and CONFIG_KM_RESERVED_PRAM definesValentin Longchamp
This prevents u-boot from accessing into the reserved memory areas that we have for /var and the logbooks. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-05-13kmp204x: selftest/factory test pin supportValentin Longchamp
This patch defines the post_hotkeys_pressed() function that is used for: - triggering POST memory regions test - starting the test application through the checktestboot command in a script by setting the active bank to testbank The post_hotkeys_pressed return the state of the SELFTEST pin. The patch moves from the complete POST-memory test that is too long in its SLOW version for our production HW test procedure to the much shorter POST-memory-regions test. Finally, the unused #defines for the not so relevant mtest command are removed. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-12freescale: pblimage: refactor CONFIG_SYS_FSL_PBL_{PBI, RCW}Masahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_FSL_PBL_PBI and CONFIG_SYS_FSL_PBL_RCW and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: York Sun <yorksun@freescale.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
