path: root/include/configs/km8360.h
2017-09-01Convert CONFIG_BCH to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_BCH Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-18powerpc/km8360: fix the ODT parameters for CS0Valentin Longchamp
The ODT parameters for km8360 set the ODT_WR_ACS bit in u-boot KM-2011.09 that is used in the release bootpackage for kmcoge5ne. During the transition from the kmeter1 to km8360 this was changed to ODT_RD_ONLY_CURRENT, which is uncorrect and causes faulty RAM accesses at low temperatures. This is now changed to ODT_WR_ONLY_CURRENT which is the equivalent of ODT_WR_ACS. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-03-17mpc83xx: preempt premature board support removal by setting GENERIC_BOARDKim Phillips
Boards that haven't been converted to GENERIC_BOARD does *not* mean they should be removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2013-02-15powerpc/83xx: use NAND_ECC_BCH for kmcoge5neHolger Brunck
Switch from 1-bit ecc to 4-bit ecc. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2012-06-15powerpc/83xx: configure CONFIG_POST for kmcoge5neThomas Herzmann
kmcoge5ne starts the post tests if the testpin on the board was enabled. Currently it does simply a memory test. Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-06-15powerpc/83xx: add kmcoge5ne board supportHolger Brunck
This board is a MPC8360 board. Two flashes are present a NOR flash were u-boot and the u-boot environment is stored and a NAND flash for the application code. This board has 512MB SDRAM. Additionaly we introduce a common km8360.h file and convert kmeter1 to use this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Christian Herzig <christian.herzig@keymile.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
