path: root/include/configs/km8360.h
2013-02-15powerpc/83xx: use NAND_ECC_BCH for kmcoge5neHolger Brunck
Switch from 1-bit ecc to 4-bit ecc. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2012-06-15powerpc/83xx: configure CONFIG_POST for kmcoge5neThomas Herzmann
kmcoge5ne starts the post tests if the testpin on the board was enabled. Currently it does simply a memory test. Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-06-15powerpc/83xx: add kmcoge5ne board supportHolger Brunck
This board is a MPC8360 board. Two flashes are present a NOR flash were u-boot and the u-boot environment is stored and a NAND flash for the application code. This board has 512MB SDRAM. Additionaly we introduce a common km8360.h file and convert kmeter1 to use this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Christian Herzig <christian.herzig@keymile.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
