- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The HW guys suggested to change these two values. And these values are
now identical to the values we use on mgcoge.
PSDMR_WRC was set to 1C as it should lead to better performance.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
mgcoge2ne was an intermediate step towards mgcoge3ne. One difference is the
smaller SDRAM on mgcoge2ne (128MB). To support both boards with the same
u-boot we use here the SDRAM detection.
This patch enables SDRAM detection between 256MB and 128MB.
So in addition to the existing 256MB geometry:
4 chips x 8M (13 rows, 10 cols) x 16 bit x 4 banks
we can now also have 128MB geometry:
4 chips x 4M (13 rows, 9 cols) x 16 bit x 4 banks
The only file including km82xx-common.h is km82xx.h.
So there is no need to have it as a separate file.
Since mgcoge and mgcoge3ne are the only km82xx boards, there is no need
to keep them as separate .h config files.
Therefore, make mgcoge3ne.h and mgcoge.h converge into a single km82xx.h
file.
