path: root/include/configs/km/km_arm.h
2016-10-23video: Drop CONFIG_CONSOLE_INFO_QUIETSimon Glass
This is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18km: update the boot script to check for a DTBValentin Longchamp
If a DTB is found with cramfsls, the bootscript continues as expected. If none is found, the cramfsloadfdt and boot subbootcmds are updated to not load the DTB from cramfs and not pass it to the kernel. The kernel thus must have an appended DTB otherwise the boot will fail. This is required for the km_kirkwood boards that must support .esw where the DTB sometimes is appended (for backwards compatibility) and sometimes is passed correctly (as we do now for all newer boards). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18arm/km_kirkwood: remove KM_ENV_BUS and use CONFIG_I2C_ENV_EEPROM_BUSValentin Longchamp
KM_ENV_BUS was used for nothing else than an direct assignment to CONFIG_I2C_ENV_EEPROM_BUS. To avoid this, directly use CONFIG_I2C_ENV_EEPROM_BUS instead. Patchwork: http://patchwork.ozlabs.org/patch/399411/ Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-21ARM: kirkwood: move SoC headers to mach-kirkwood/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-kirkwood/* -> arch/arm/mach-kirkwood/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2014-11-12km_arm: convert the km_arm boards to the generic board supportValentin Longchamp
This implies that all the km_kirkwood boards and their variants now are using the generic board init sequence. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-02-13arm/km: define fdt_high env variable and allow backwards compatibilityGerlando Falauto
Add set_fdthigh subcommand to "subbootcmds" (release) so to set "fdt_high" This is necessary on Kirkwood so that the FDT does not get relocated above the memory limit that the kernel cannot access (that is the memory part reserved for the switch). This was tested on NUSA1, where it is necessary, and on ETER1, where it doesn't seem to hurt. We want the scripts to also work with older versions of u-boot, where: a) set_fdthigh is not defined (will be default env for newer u-boots) b) the fdt will not be available For this reason, we use "set_fdthigh" to tell whether we are running a newer (FDT-aware) u-boot or not. So if "set_fdthigh" runs successfully or arch != arm we try loading the fdt; otherwise we proceed normally. Notice how, contrary to release mode, set_fdthigh will _not_ be part of subbootcmds for develop and ramfs, but will be executed as part of "tftpfdt". Since this is only needed for kirkwood cards, and it prevents the kernel from booting on QorIQ (though it seemed to work on ETER1), we change its definition in the default env for powerpc so that the value is only set on ARM. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-02-13arm/km: enable FDT for km_kirwkoodGerlando Falauto
This consists of: a) Defining the addresses, enabling fdtsupport [arm] b) Defining "cramfsloadfdt" [arm,powerpc => common] c) Adding the FDT address to bootm [arm,powerpc => common] d) Defining "tftpfdt" in ramfs-,develop- [arm,powerpc >= common] This should work with 3.10 kernels, whether loaded through TFTP (with rootfs either through NFS or TFTP-ramfs) or from the NAND. The machid was left unchanged, this should keep compatibility with both older and newer kernels. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-02-13arm/km: add CONFIG_KM_BOARD_EXTRA_ENV to default environmentHolger Brunck
This is needed for board specific additional environment variables. E.g. the mgcoge3un has this additional "waitforne" variable. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24KM: add CONFIG_KM_COMMON_ETH_INIT for km common eth initValentin Longchamp
This must be defined by a board support file that want to use the keymile common.c board_eth_init function that requires ethernet_present to be defined. Currently all the km architectures use it but the kmp204x architecture later supported in this series does use another board_eth_init function and thus does not define it. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24KM: define CONFIG_SYS_I2C_INIT_BOARD only for concerned boardValentin Longchamp
This must be defined for all the keymile boards that use the common i2c_abort function that is used to "reset" the I2C bus. These are currently km82xx and km_arm boards. The km83xx boards use other functions and thus do not need this. This patch removes the CONFIG_SYS_I2C_INIT_BOARD from keymile-common.h and defines it for km_arm.h and km82xx.h. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24km-powerpc: move SYS_MALLOC_LEN out of keymile-common.hValentin Longchamp
It must be set to a different value for the later add kmp204x architecture, because we are restricted to 1MB SRAM. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23arm/km: fix u-boot update functionalityHolger Brunck
Due to the new I2C framework we need to adapt the u-boot update function. Due to the new framework all i2c leafs behind a mux are present in the system and not only those who are defined and used. So it is bus number 5 after the rework. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2013-07-23i2c, multibus, keymile: get rid of EEprom_ivm envvariableHeiko Schocher
as the keymile boards use now the new i2c multibus/multiadapter framework, remove the EEprom_ivm Environmentvar, as not longer needed. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Holger Brunck <holger.brunck@keymile.com> Tested-By: Holger Brunck <holger.brunck@keymile.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-04-12arm/km: use CONFIG_NAND_ECC_BCHHolger Brunck
Switch from 1-bit ecc to 4-bit ecc. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2013-04-12arm/km: rename BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITHolger Brunck
commit 9660e442 cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INIT removes BOARD_LATE_INIT and uses CONFIG_BOARD_LATE_INIT instead. Therefore we have to use this define. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2012-10-15COMMON: Use __stringify() instead of xstr()Marek Vasut
Kill multiple occurances and redeclaration of xstr in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-09-03arm/km: fix frequency of the SPI NOR FlashValentin Longchamp
According to our last HW measures, this could be raised while still compatible with the potential delays on the lines. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2012-09-03km/arm: set SPI NOR Flash default parametersValentin Longchamp
These parameters are used by the the sf probe command that are used by our update script and they therefore need to be set for all of our boards. The timing is the same as for the ENV SPI NOR Flash (since it's the same physical device) and takes the boco2 delay on the bus into account. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07arm/km: remove calls to kw_gpio_* in board_early_init_fHolger Brunck
These functions tried to access two static tables before relocation (board_early_init_f is executed before relocation). But these static tables lie in the bss section which is not valid before relocation. These accesses then overwrote some parts of u-boot binary before it was relocated. For the kmnusa build, this results in a corrupted important env variable (bootcmd) but it may be that some other parts of the u-boot binary are corrupted. This patch solves this problem by moving all the kw_gpio_* calls to board_init, which should be early enough in the boot sequence. The only calls that could not be moved is the one for the SOFT (bitbang) I2C, and they have been replaced by a direct access to the GPIO dataout Control register to set the two GPIOs as output. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: enable BOCO2 FPGA download supportValentin Longchamp
This adds a first support of the FPGA download for a PCIe FPGA based on the BOCO2 CPLD. This takes place in 3 steps, all done accessing the SPICTRL reg of the BOCO2: 1) start the FPGA config with an access to the FPGA_PROG bit 2) later in the boot sequence, wait for the FPGA_DONE bit to toggle to 1 for the end of the FPGA configuration (with a timeout) 3) reset the FPGA 4) finally remove the access to its config EEPROM from the FPGA so that the CPU can update the FPGA configuration when the kernel is running The boards with a PCIe FPGA but without BOCO2 still are supported. The config option name is CONFIG_KM_FPGA_CONFIG Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: add kmnusa board supportHolger Brunck
This board is similar to portl2, but it has the u-boot environment in a SPI NOR flash and not in an i2c eeprom like portl2 have. Some other details: - IVM EEPROM is at adress: pca9547:70:9 - PCI is enabled - PIGGY4 is connected via MV88E6352 simple switch. There is no phy between the simple switch and the kirkwood. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: use spi claim bus to switch between SPI and NANDValentin Longchamp
We overwrite these weak functions from the kirkwood spi code to use our own method to be able to switch between the SPI NOR and the NAND flash. This is needed e.g. to update the u-boot. The former command do_spi_toggle can therefore be removed. And the usage of this command is removed from the u-boot update command in the u-boot environment. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07km_arm: use filesize for erase in update commandValentin Longchamp
We used to have an arbitrary value, which can be a problem if we have a u-boot image that is bigger than this value. This patch is dependant on the whole km/arm series and will be included in the v3 of the series if there is one. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: enable mii cmdValentin Longchamp
This is useful to debug the switch initialization Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: remove CONFIG_RESET_PHY_RHolger Brunck
This is already defined in the generic kirkwood header. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-07-07arm/km: rename CONFIG option CONFIG_KM_DEF_ENV_UPDATEHolger Brunck
This config option sounds like the it is responsible for the update of the environment, but it is the u-boot update handling. Therefore we adapt it to a more apropriate naming. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-06-15km/common: add support for second flashAndreas Huber
Add support for a second flash. By default, a single flash chip is set up: - called 'boot' - mtd name for ubi 'ubi0' MTDIDS and MTDPARTS may be overwritten to add a second flash. The 'ubiattach' command is featured in two versions: - if CONFIG_KM_UBI_PARTITION_NAME_APP is not defined: this is the version as up to now - if CONFIG_KM_UBI_PARTITION_NAME_APP is defined: a check on 'actual_bank' will be done to determine the flash to boot from. Use CONFIG_KM_UBI_PARTITION_NAME_BOOT and CONFIG_KM_UBI_PARTITION_NAME_APP to define where to put the bootloader and the applications. Example: In the board config do: ... snip ... "boot:" \ "768k(u-boot)," \ "128k(env)," \ "128k(envred)," \ "-(" CONFIG_KM_UBI_PARTITION_NAME_BOOT ");" \ "app:" \ "-(" CONFIG_KM_UBI_PARTITION_NAME_APP ");" ... snap ... You may also need to enable the second flash: ... snip ... /* additional featured for COGE5 */ ... snap ... Signed-off-by: Andreas Huber <andreas.huber@keymile.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-02-12arm/km: speed up i2c access for keymile boardsHolger Brunck
We don't need 3us delay for our i2c bus. Decrease it to 1us. It would also be possible to use 100ns in the future, but currently kirkwood has no ndelay implementation. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2012-01-26NAND: remove NAND_MAX_CHIPS definitionsVladimir Zapolskiy
This change follows the change by Wolfgang Grandegger (commit 6c869637fef), which allows to remove useless NAND_MAX_CHIPS definitions in board config files. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-11-03arm/km: enable jffs2 cmdsHolger Brunck
Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-11-03arm/km: add boardid and hwkey to kernel command lineHolger Brunck
We need in some cases a possibility for the kernel to distinguish on which board he is running. On powerpc we did this with different dts files. On arm currently we can't do this, so add boardid and hwkey to the kernel command line and use it later on in the kernel code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-11-03ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boardsValentin Longchamp
We got dropped from Linux mach-types.h because of a lack of mainline support and this is needed since the last Linux/u-boot mach-types synchro. This patch also defines CONFIG_MACH_TYPE for all keymile boards, as this is a mandatory CONFIG for ARM boards now. The initialization of gd->bd->bi_arch_number is removed form km_arm.c, our board file. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-10-24Revert "km_arm: enable POST for these boards"Wolfgang Denk
This reverts commit a2da616311151ecfab8b8fcc510686fc3c0c9a21. THis was applied by accident - a more recent version of this change was already present, see commit 9400f8f 2011-10-05 22:03:11 +0200 km_arm: enable POST for these boards Signed-off-by: Wolfgang Denk <wd@denx.de>
