Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_CMD_JFFS2
CONFIG_CMD_IMMAP
Also move this command out of the cmd/ directory since it is
PowerPC-specific.
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
This option does not exist in U-Boot. Drop it.
CONFIG_CMD_CRAMFS
[trini: imply CMD_CRAMFS for keymile]
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
move VERSION_VARIABLE from board config file into a
Kconfig option.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
This option doesn't do anything. Drop it.
Suggested-by: Bin Meng <bmeng.cn@gmail.com>
If a DTB is found with cramfsls, the bootscript continues as expected.
If none is found, the cramfsloadfdt and boot subbootcmds are updated to
not load the DTB from cramfs and not pass it to the kernel. The kernel
thus must have an appended DTB otherwise the boot will fail.
This is required for the km_kirkwood boards that must support .esw where
the DTB sometimes is appended (for backwards compatibility) and sometimes
is passed correctly (as we do now for all newer boards).
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
To prevent u-boot to stop accidently e.g. due to line noise on the
serial line, we now use the option CONFIG_AUTOBOOT_KEYED. We choose the
<SPACE> key for this.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
them from include/configs.
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Add set_fdthigh subcommand to "subbootcmds" (release) so to set "fdt_high"
This is necessary on Kirkwood so that the FDT does not get relocated
above the memory limit that the kernel cannot access
(that is the memory part reserved for the switch).
This was tested on NUSA1, where it is necessary, and on ETER1, where it
doesn't seem to hurt.
We want the scripts to also work with older versions of u-boot, where:
a) set_fdthigh is not defined (will be default env for newer u-boots)
b) the fdt will not be available
For this reason, we use "set_fdthigh" to tell whether we are running
a newer (FDT-aware) u-boot or not.
So if "set_fdthigh" runs successfully or arch != arm we try loading
the fdt; otherwise we proceed normally.
Notice how, contrary to release mode, set_fdthigh will _not_ be part of
subbootcmds for develop and ramfs, but will be executed as part of
"tftpfdt".
Since this is only needed for kirkwood cards, and it prevents the kernel
from booting on QorIQ (though it seemed to work on ETER1), we change
its definition in the default env for powerpc so that the value is only
set on ARM.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
This consists of:
a) Defining the addresses, enabling fdtsupport [arm]
b) Defining "cramfsloadfdt" [arm,powerpc => common]
c) Adding the FDT address to bootm [arm,powerpc => common]
d) Defining "tftpfdt" in ramfs-,develop- [arm,powerpc >= common]
This should work with 3.10 kernels, whether loaded through TFTP
(with rootfs either through NFS or TFTP-ramfs) or from the NAND.
The machid was left unchanged, this should keep compatibility with both
older and newer kernels.
This define can be used if the ubi boot partition (defined for all
Keymile boards with KM_UBI_PARTITION_NAME_BOOT #define to ubi0) needs
some additionnal boot options.
This is the case for the kmp204x boards since u-boot does not support
NAND Flash subpage accesses on this platform, an additionnal argument
that defines the VID offstet must be given to the kernel.
The UBI cmd line option now looks like this "ubi.mtd=ubi0,2048" on this
platform.
Reviewed-by: York Sun <yorksun@freescale.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
This must be defined for all the keymile boards that use the common
i2c_abort function that is used to "reset" the I2C bus. These are
currently km82xx and km_arm boards.
The km83xx boards use other functions and thus do not need this.
This patch removes the CONFIG_SYS_I2C_INIT_BOARD from keymile-common.h
and defines it for km_arm.h and km82xx.h.
The ip kernel parameter had a typo in it (we've been lucky that it has
worked until now).
It must be set to a different value for the later add kmp204x
architecture, because we are restricted to 1MB SRAM.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
These boards define CONFIG_LAST_STAGE_INIT and CONFIG_BOARD_EARLY_INIT_R
but these options are not available on ARM. Move them into the powerpc
common file instead.
This change affects: km_kirkwood_pci, mgcoge3un, kmnusa, kmcoge5un,
km_kirkwood and portl2.
If CONFIG_NAND_ECC_BCH is chosen from in the board configuration we add
an ecc mode to the kernel commandline.
Replace the hardcoded string with a variable. If CONFIG_NAND_ECC_BCH is
set we use a specific name for the uImage (ecc_bch_uImage).
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
These variables are only used if CONFIG_SYS_CONSOLE_IS_IN_ENV
is set. This isn't the case, so we can drop them safely.
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Kill multiple occurances and redeclaration of xstr in favor of __stringify().
For some reasons we had an own implementaion of dram_init and
dram_init_banksize. This is not needed anymore, use the standard
kirkwood functions instead.
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
If the testpin is asserted, first check if a test_bank
variable is defined before trying to boot this
test_bank.
Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com>
Increase bootlimit to 3 to be more tolerant during the
boot process before switching to the backup application.
Add support for a second flash.
By default, a single flash chip is set up:
- called 'boot'
- mtd name for ubi 'ubi0'
MTDIDS and MTDPARTS may be overwritten to add a second flash.
The 'ubiattach' command is featured in two versions:
- if CONFIG_KM_UBI_PARTITION_NAME_APP is not defined:
this is the version as up to now
- if CONFIG_KM_UBI_PARTITION_NAME_APP is defined:
a check on 'actual_bank' will be done to determine the flash to boot
from.
Use CONFIG_KM_UBI_PARTITION_NAME_BOOT and
CONFIG_KM_UBI_PARTITION_NAME_APP to define where to put the bootloader
and the applications.
Example:
In the board config do:
... snip ...
"boot:" \
"768k(u-boot)," \
"128k(env)," \
"128k(envred)," \
"-(" CONFIG_KM_UBI_PARTITION_NAME_BOOT ");" \
"app:" \
"-(" CONFIG_KM_UBI_PARTITION_NAME_APP ");"
... snap ...
You may also need to enable the second flash:
... snip ...
/* additional featured for COGE5 */
... snap ...
cc: Kim Phillips <kim.phillips@freescale.com>
Calucations of PRAM needs to take into account the 'rootfssize'.
Memory available to the linux kernel 'mem=' is in all cases set to the total
memory size minus the pram size.
cc: Wolfgang Denk <wd@denx.de>
Moved eeprom config to specific part, to allow bigger eeprom write pages
for km_kirkwood designs. Write page only used for env eeprom in std use
cases. 24C128 has page size of 64bytes -> 8 time faster.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
cc: Heiko Schocher <hs@denx.de>
Now we use the standard u-boot make to build the Kirkwood binary.
The output file is u-boot.kwb. So use this name for the tftp
update function to avoid confusion, because this is the binary we
need on Kirkwood.
All the km boards uses CRAMFS images where the kernel is stored.
This isn't architecture specific because we use it on ARM and
POWERPC.
These defines and the header keymile_hdlc_enet.h are obsolete
due to the removed hdlc code.
