path: root/include/configs/kc1.h
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01kc1: Add some sysboot and devicetree-related environment variablesPaul Kocialkowski
This adds some environment variables for sysboot and devicetree. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-04-01kc1: Include explicit serial baudrate on bootargsPaul Kocialkowski
This makes the baudrate for the kernel command line explicit. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-15kc1: Power off when the power on reason is not a valid onePaul Kocialkowski
Some power on reasons are not desirable (e.g. too short press on the power button), battery plug. Thus, power off the device when one of those occurs. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15kc1: OMAP4 reboot mode supportPaul Kocialkowski
This adds support for the omap4 reboot mode mechanism and exports the reboot mode via an environment variable, that is used in the boot command to make it possible to boot from the recovery partition or fastboot. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15kc1: MUSB USB controller and fastboot USB gadget supportPaul Kocialkowski
This adds support for the MUSB USB dual-role controller in peripheral mode, with configuration options for the fastboot USB gadget. At this point, flashing the internal eMMC is support. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15Amazon Kindle Fire (first generation) codename kc1 supportPaul Kocialkowski
The Amazon Kindle Fire (first generation) codename kc1 is a tablet that was released by Amazon back in 2011. It is using an OMAP4430 SoC GP version, which allows running U-Boot and the U-Boot SPL from the ground up. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
